#251879 06/29/02 09:45 PM
TonyD Offline OP
I just finished the rear disk conversion! Only thing is I now have abs light on. Code says it's a bad sensor. Question is can i just swap the one from my drum set? Plugs look the same except different colour?
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
#251880 06/30/02 12:59 AM
You could try, are the abs rings the same on the drums versus the discs? My guess you will need a new sensor for one from discs, other wise if it was working before maybe make sure its lined up correctly and reading the rings right.
2000 Roush Cougar MTX
MSDS Headers, Rear disc conversion, SVT TB and IM, Custom 2.5" exhaust, Weapon R Dragon w/kkm MAF adaptor, B&M, NR wht gauges
Moderated by  Andy W._dup1
