#251854 06/27/02 01:30 AM
W
wingo Offline OP
W
Hi My front rotor is toast I tried to get it off but it is rusted on does anyone have info on this problem
#251855 06/27/02 04:37 PM
on mine there were some thin like washer screws on the studs holding the rotor on. but if its just rust holding it on get a hammer.
GO WINGS!
99 SVT Silver w/ Blue Stripe with some mods. mike4420@comcast.net
"To each his own"
#251856 06/30/02 05:59 PM
Retainer washers neet to come off as mentioned and you may need to get some rust buster and try squirting it where the studs come through the rotors. Tap all around the rotor hub area with a hammer for several minutes to loosen rust. Avoid hittint the rotor if you plan to re-use at all. Another trick is to have someone push outward on the rotor while you tap the studs with a hammer. (use a nut to protect the threads.)
Scott
#251857 06/30/02 11:41 PM
Don't tap the studs, you can really cause yourself trouble. Beat the living hell out of the rotor face. The center hub welds itself to the rotor via rust, and you have to break it up. Hit the rotor from behine, careful not to hit anything else (I just did this today)
Just call me Judge.
People suck.
Life begins at 170mph...until that point it is just boring.....
#251858 07/01/02 12:25 AM
Make sure you aren't stingy with the anti-sieze on the new one, so this won't happen next time. I feel for you; this happened to me. Spent 3 days total to replace all 4 brakes. Overnight WD-40 didn't help. A torch did, to a degree. What worked best was hitting the rotor on the edge (where the cooling vents are). Still took a bunch of pounding and a bunch more swearing.
Moderated by  Andy W._dup1
