Posts: 2,848 |
Caliper brackets are definately different, you will have to use the FSVT caliper brackets w/ the FSVT calipers. Are you talking for non SVT's because, again, they bolted right up to Chris' car. And the wheels fit just fine too. And they are filled up quite nicely! The only "issue" chris mentioned was that he heard the FSVT bolts are longet than the CSVT, so it's a good idea to change them anyway.
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 1,028 |
Yes, I bolted my E1 wheels over the FSVT caliper and rotor and it fit. I also have my wheels balanced by those little sticky weights on the inside of the dish, not on the face of the wheel. Bill J. did tell me the FSVT caliper bolts are approx. 1/2" longer. Since my caliper bolts are corroding, I order the FSVT bolts. For the rears, I hope to do it sometime in early September, I've used up my car budget for this month!
Chris NJ 98.5 SVT Silver Frost w/Frankentrans carsla AT optonline DOT net
Posts: 3,248 |
This is excellent new..thanks guys. So, what did the set up cost, is it readily available at this time?? I smell group buy!
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 1,375 |
I will try to get a friend with a digicam to come over during the install to help document the process. It does seem pretty much a straight swap. I'll Try to get there soon :p
99 SVT Tropic Green #151 of 503/ 2760 total Born on 10/07/98 Adopted 7/15/00 LETS GO RANGERS (looking good this year)
Posts: 1,028 |
Originally posted by Dan Nixon: This is excellent new..thanks guys.
So, what did the set up cost, is it readily available at this time?? I smell group buy! I'll check the prices when I get home from work tonight. Also, Bill said the parts should be in stock soonly.
Posts: 1,028 |
Prices: DSC-FRT: 95.00 (list) 71.25 (sell) BRAKE AS: 130.09 (list) 97.56 (sell) CORE CHG: 70.00 (list) 70.00 (sell)
Now, I have purchased many, many items from Bill (both bumpers, full set of wheels, maintenance items, hard to get bearings, etc...) so these prices that he gets me may be better than other people's prices. Hell, other people may be getting better prices than me! So, YMMV...
Oh yeah, this is per side.
Posts: 69 |
"the rats are on the cheetos again" Jet mechanic 98 silver frost SVT DMD K&N FILTER 36,300 MILES PIONEER 6CD CHANGER AND SPEAKERS 2 BAZOOKAS
