So I ordered some Speed Bleeders the other day. Installed them and bled the brakes without a hitch. They definately are as easy as it says they are to install.
Everything was fine and dandy for a week or so. Brakes felt damn good. Well last night I was driving a bit "spirited" and ABS kicked in.
So now my brakes are a little mushy. I think this is the first time I've used the ABS since I bled the lines.
Is there air in the ABS system? Do i just need to re-bleed the brakes? Should I use the ABS right before I bleed the brakes?
When I went to a track event in February I'm pretty sure I boiled the fluid. I thought I've bled it all out but I guess I was wrong.
So any suggestions?
Thanks,
Jason
