Page 2 of 2 1 2
#251763 06/20/02 03:13 AM
Yeah, you should be fine, I have them stuffed under 17 in RS5's with no spacers, etc. There's about 1/8" clearance, but whatever, fills up my wheels for sure.
'98 Black SVT #651 of 6535
KKM Intake (Miks Heat Shield in Winters/Drop-in K&N Summers), SHO Y-Pipe, and Bassani Exhaust.
Eibach Pro-Kit, Koni Struts, and Enkei RS5's with BFG-KDWs (215/45-ZR17)
BAER 13" big brake kit+rear baer rotors all zinc washed, cross-drilled and slotted (Greenstuff binding rears)
Kenwood head unit with Infinity reference speakers+1 8" Bazooka Tube fed by two MTX Blue Thunder amps.
Hella Stage II HIDS from hids4less.com.
Recaro Sport Seats trimmed in supple black leather.
And Zymol wax to keep it squeaky clean.
#251764 06/20/02 03:14 AM
tckn19s Offline OP
Alright. Thanks.
Knew I could count on someone to have other experiences, other that the worst case scenario. :p :rolleyes:
#251765 06/20/02 03:37 PM
I guess I'm not so wrong!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
#251766 06/20/02 03:42 PM
You know that's not what Antonio meant..
You come out with a blanket statement that anything 17" or bigger will clear fine. Very large assumption that leaves out the spoke design of the wheels. Antonio's 19's don't fit the Baer kit without modification. I'm sure there is plenty of the 17" stuff the doesn't either.
Just a warning to be careful, download the Baer templates, and do your homework.
#251767 06/20/02 03:55 PM
The only necessity of the Baer kit is 17's everything else is based on what kind of rims you have.
Willwood's require spacers for 16's, outside of that, it depends on your rims.
I said they should fit not will and from what I remember of Bernie's rims I thought they should.
I've already talked with Ant!
-Andy
Andy Watson
Graci!
#251768 06/23/02 09:31 PM
My 17" Superleggeras cleared just fine.
98.5 Contour SVT
Page 2 of 2 1 2
Moderated by  Andy W._dup1
