sinned Offline OP
This is driving me nuts i don't get it right away after about 15 minutes of stop and go traffic the breaks let out a squeal with light braking form there it turnes into a grinding sound (the disk are fine checked and rechecked by ford) i had the disk cut and new pads put on but it still happens it drives me nuts! mad i've had the brakes cleaned as well i have a 95 se with the 4wheel Disk and ABS. Please help post any questions or statments i really apreatiate the help. confused
1995 Contour SE
champaign
dwh Offline
Have you tried different brands of pads? Try changing only one thing at a time until you notice a difference in the problem. At that point you will have come close to isolating the cause. But from your description, it would seem that it is a pad issue more than a rotor issue. Does your brake pedal "pulse" or "shudder" when you are braking? That would probably indicate a rotor issue. "Grinding" as I would describe it would be the sound of worn out pads contacting the rotor surface... A metal on metal sound. If it doesn't grind all the time while using the brakes, I don't see how it would only grind occasionally. Possibly you are describing something else? Try bleeding and flushing your brakes also?
95 mystique LS, High Output Cougar S (SVT) 2.5L engine & MTX75
squeal and grinding? Sounds like what has gone on in the back seat of my car! laugh :p
98 V6 Lots-o-mods SOLD
88 Daytona Shelby Z TII (The beast)
87 Daytona Shelby Z TII (Holy 20 psi of boost batman!)
Mods- 3" Downpipe, Hi-Flow cat, 3" mandrel bent exhaust with Dynomax Ultra flow. Manual boost controller, TurboXS blowoff, 5th injector, large canister wastegate, Nitrous Express go-fast-be-happy kit, ported exhaust manifold, ported intake manifold, upgraded motormounts, eibach springs, strut tower brace. Oh and 20 PSI to boot.. my oh my...
sinned Offline OP
Ha Ha SeR Guy, but anyway i got brand new ford OEM pades from bill Jenkins when he was at sentry south i was in boston when his techs put them on and said a ok
1995 Contour SE
champaign
Moderated by  Andy W._dup1
