I just wnated to make sure that I had the right part number before I orderd mine as when I was looking in past posts I ran into a bit of confusion.
According to the speed bleeder website, the correct part numbers are SB1010 (front) and SB1010S (rear) but in a later post I read that the later SVT's (I'm assuming because of the smaller calipers on the E1's vs the E0's) that if a 9mm wrench fits the bleeder head I need SB8125L for the front.
I have the smaller calipers and my OE bleeder does use a 9mm wrench.
So what do I order?
OR
SB8125L (front) and SB1010S (rear)
Evan Groenke
1999 Silver Frost SVT #1919
183.9hp 163.7lb/ft tq @ the wheels
Now bitter at Ford
dwh Offline
I am not sure myself, but they are talking about it in the performance forum here:
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=6;t=004654
95 mystique LS, High Output Cougar S (SVT) 2.5L engine & MTX75
So what do I order?
OR
E1's - SB8125L (front) and SB1010S (rear)
95-E0 - SB1010 (front) and SB1010S (rear)
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
Since I drive me car inthe winter (salty) months, should I sped the extra cahs and order the ones in 303 stainless steel, or is it a waste of money for them? (probably a dumb question)
Evan Groenke
Now bitter at Ford
So would these work for my 2000 SVT? Thanx
00 Black SVT #1545
Ground Control. Koni. 18" Konig Tantrum. More.
Moderated by  Andy W._dup1
