Originally posted by Todd TCE:
Wheel spacer are not a bad thing if you consider two issues:
First the centering of the wheel. Many wheels are 'hub centric' and require the center of the wheel fit the hub. If you add too much spacer then you may loose this and have rotational problems of the wheel. Most aftermarket wheels suck in this area as they are multi application and mass produced. Factory wheels seem to tollerate the loss of this better, they are stud centric.
Todd, just to clarify something, most modern cars seem to use a "hub centric" wheel setup not only for the obvious centering purpose, but also to make the hub support some of the car's weight. You definitely don't want to take that away and transfer all the weight on the studs. OEM SVT wheels are hub-centric just like any other aftermarket rim should be.. for the Contour application at least!
