I have had a moaning when say I am doing 70 and have to slow down fairly fast is this normal. I have not had any stopping loss just that moaning like rideing on a groved road.
98 'tour silver
KKM
svt exhaust
svt wheels
stereo mods=kenwood head unit
alpine amps installed
12" kicker comp vr sub
purple calipers
www.angelfire.com/realm2/silverbullet/contour.html
http://members.sounddomain.com/silverbullet02
Mods to come!
purple neons
marker lights
PUTER chip
svt body kit
lowering job
PROBABLY IN THAT ORDER!
_ _ _ _ _ _ _ _ ___ _ _ _ _ _ _ _ _
Could it be the ABS? The ABS makes a groaning / pounding / howling noise if you were braking hard enough to invoke the ABS.
Although not common on our cars, a similar noise can come from hot spots on the rotors. If it is from hot spots, it tends to get worse as the brakes heat up, and it will be there most of the time. Hot spots cause rotor thickness variation which generates a pounding while braking. The rotors will have a pattern of dark blue or black spots on the friction surface mixed with the normal silver color.
Jim Johnson
98 SVT
Moderated by  Andy W._dup1
