Posts: 1,202 |
Finally got these in this week. They will be installed on our SVT on April 6, 2002. Here is a couple of pics.  More pics in my sig. Follow Project 98.5 SVT.
Posts: 86 |
chris, i'm about to order those too...they look awesome!!! one question, and this is to strictly verify, are those brake lines S/S? they look like it....your pics look a hell of alot better than the ones in the BAT catalog.... did you have to get spacers?????? if so where did you get them???? i heard tirerack.com has em'...but i haven't checked it out yet....
99'Contour SVT #1766 of 2760 stock-for now, mods in the making pionner deh-4400 cd/xm head unit pioneer 4x6 component plates(front) pioneer 3-way 6x9 (back) (2)8" Boston Accoustic Rally Series subwoofers Alpine 3527 amplifier MTX RT-XO1A electronic crossover
Posts: 50 |
Depending upon cost, you may want to hold your $ for a couple of weeks until I finalize another option for you. The use of the NDL caliper in my proposal will be equal to what is here as they are the same caliper with alternate ears on them. Difference is that my proposed modular design will allow you to use this caliper for the stock wheel (the plan anyhow) with my rotor package, then if you have larger wheels you can 'up size' the calipers to the Superlite level using the same mounting brackets, same rotor, or enlarge the rotor also....flexability is what it's about.
Posts: 1,202 |
Originally posted by 99SVT1766: chris, i'm about to order those too...they look awesome!!! one question, and this is to strictly verify, are those brake lines S/S? they look like it....your pics look a hell of alot better than the ones in the BAT catalog....
did you have to get spacers?????? if so where did you get them???? i heard tirerack.com has em'...but i haven't checked it out yet....Yes, those are SS lines provided in the kit. Can't tell you about the spacers yet, as they will not be installed until April 6th. We can get spacers from any of our local wheel and tire dealers.
Posts: 636 |
you will need 5mm spacers to fit them on.....fyi.
Posts: 2,166 |
Damn those Dynalite's look sexy I think its time to replace my old SuperLites
Posts: 152 |
where did u get the wilwood dynalite calipers and do they fit a 99 se sport?and price would be helpful.
99 Contour JOSE AIM:elflaco1981
Posts: 250 |
Originally posted by Todd TCE: Depending upon cost, you may want to hold your $ for a couple of weeks until I finalize another option for you. The use of the NDL caliper in my proposal will be equal to what is here as they are the same caliper with alternate ears on them. Difference is that my proposed modular design will allow you to use this caliper for the stock wheel (the plan anyhow) with my rotor package, then if you have larger wheels you can 'up size' the calipers to the Superlite level using the same mounting brackets, same rotor, or enlarge the rotor also....flexability is what it's about. Whats the scoop on your rotor package? I checked out the site and you don't have any info on the tour stuff, I know its a new line for ya, but i would like to get some more info.
98 SE BAT Big Brake Kit "C", Throttle Hang Fix, B&M Shifter, Lightly Cracked Secondaries, BAT Euro Handling Kit, 20% tint, Removed Ding Strips, ES Motor Mount Inserts, Borla CatBack, Apexi SAFC, HighTower Rear Brace, BAT 19mm rear bar, MSDS Headers & Y, AFE 20-35008 filter, ClutchMasters Stage 1, Fidanza FlyWheel, SVT T.B. ====OnOrder==== svt uppers and lowers,
Posts: 50 |
There is no info on the kit on the site, sorry. Brackets of the corrected dimensions are being made up in the test phase of things. Once I confirm them to be as I wish I can better come to grips with the final packages. Sorry for any delays, but it's either this or I sell you some BS that you complain about not fitting etc. and do it while asking for money up front. This is not the way I work. When I'm satisfied with it I'll let everyone know and even later I've been known to ship out updates on things I've improved along the way. I usually find people are more receptive to this than simply asking for your CC and telling you it's in the works. Please be patient, it's only been a couple of weeks at best since I started this project and it's hardly the only one I'm working on.
Posts: 86 |
BAD NEWS....i can't get the brake kit.... the other day my clutch went out and it is costing me $1,100 to get it replaced  ....so the brake kit has to wait....i just going to get new rotors and the s/s brake lines from BAT... let us know how you like the wilwoods once they're installed....
