#250861 03/26/02 08:02 PM
Ted H. Offline OP
Has anyone figured out a way to disable the ABS for track use?
#250862 03/26/02 11:08 PM
Y
Y
why would you ever want to do that?
THIS CAR IS F***ING COOL!
bone stock for now...
#250863 03/26/02 11:53 PM
Pull the fuse. :rolleyes:
-Colter
My Car
#250864 03/28/02 02:23 PM
You would probably end up killing power brakes all together. Again, Why would you want to do this!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
#250865 03/28/02 06:58 PM
Since the power brake system is vacuum assited with a vacuum booster I don't see how a missing fuse would have any effect.
Some earlier ABS systems did not have vacuum assist, but instead a small electrical pump that was in use every time the brake pedal was depressed. On that system, it would have been unwise to have disabled it electircally as you would have had no brakes.
As for why someone would want to disconnect the ABS, some highly skilled drivers would rather deal with the possible skidding on their own, without electronic intervention, just as some would rather not have traction assist. Personally, I would rather have the ABS, but some would not.
Jim Johnson
98 SVT
#250866 04/01/02 03:19 AM
Sure it's easy.. just pull the fuse on it under the hood. It's the first 7.5 amp next to the 20 amps on the side next to the drivers fender.
Why would you want to do this?? Our cars have problems with locking up the back tires.. (especially if your brakes are in good shape)
We are so front heavy that under braking loads you unload the rear brakes.. and if you try to brake while going into a turn or while in a turn.. the back will lock up and spin around on you. I can't think of a single reason why I would want this to happen. Spinning in a FWD car is not my idea of fast lap times.
Dave Andrews
Black&Tan 2000 SVT 225 of 2150
Bassani.. UNCORKED
davelandrews@comcast.net
"Nothing is so firmly believed as what we least know." -Montaigne
#250867 04/04/02 01:26 AM
New Vital information about disabling the ABS on our cars.. DON'T DO IT
YOU CAN GET INTO SERIOUS TROUBLE.
Read here
http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic;f=2;t=003628
Dave Andrews
Bassani.. UNCORKED
Moderated by  Andy W._dup1
