I
I
95 mystique...the rear brakes are disc brakes correct? same as the front?
Not at all!
Smaller rotors and calipers and the emergency brake is built it to the caliper!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
In 95, the 4 cylinder Contiques had drum rears while the 6 cylinder Contiques had rear disc. It is easy to tell by looking through the wheel to see if it is a drum or a disc.
Jim Johnson
98 SVT
I
I
k thanks.....i got a 6cyl so I have discs..im all set..
yeah I figured they were smaller..since the fronts do 70% or so of the brakin
Moderated by  Andy W._dup1
