#250437 02/16/02 05:44 PM
Pinebox Offline OP
hey guys, I need some help. I'm looking for a nice set of front rotors and pads.
I was looking at EBC sport rotors, but they only come in 260mm and the Cougar has the 278mm like the SVT.
I'm leaning towards the PowerStop x-drilled from SPMotorsports. Have you heard anything about them, are they good/bad?? confused
I'll be ordering something Monday morning, I'm grinding away my right front rotor as we speak frown
Thanks
Dave,
'99 Cougar, Black, V6, MTX, loaded, and modded
oh ya, got some good tunes to
Coming soon: Yodude exhaust, Venom or NX (spring '03)
Dream: Turbo 3L (anyone need a kidney? hehehe)
#250438 02/18/02 04:31 AM
I've heard bad things (warp) about the powerstop cross-warped-drilled rotors.
I believe a lot of people have complained about warping...
I recommend slotted/grooved rotors.
BTW - grinding your rotor will add a tremendous amount of heat to the caliper and brake hose. You will most likely end up needing to replace those as well! Flushing the fluid is a no-brainer whenever servicing brakes. I recommend Valvoline SynPower.
2000 SVT #674 - Check it out!
Moderated by  Andy W._dup1
