#250317 02/06/02 03:48 PM
Swhift Offline OP
I just got ebc turbo groove rotors and was planning to install them on friday. While reading the leaflet that comes with them it says you must install new pads at the same time. Hadn't thought of that. Does anyone know any good quality pads I can get a local parts shop. Don't have time to order on-line. Thanks for any input.
#250318 02/06/02 07:56 PM
Good pads locally? Not likely. I'd order one of the Mintex sets from www.batinc.net
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
#250319 02/06/02 09:05 PM
Master P
Master P
None that I know of. I can tell you that the Raybestos pads that Pep Boys sells are crap.
#250320 02/07/02 12:56 AM
Call around for "Performance Friction". Imho the best you can do "locally", IF you can locate them. I only found ONE parts store in my area that stocked them, and we have A LOT of stores around Cleveland area. Good luck. smile
blk.99svt
n.e.Ohio
Never under estimate the power of stupid people in large groups...
#250321 02/07/02 12:58 AM
I'll have to second that. That won't dust as much as stock but they aren't that great. Just order some online, you'll be much happier you did.
#250322 02/07/02 06:43 AM
EBC Greenstuffs or Redstuffs. Tirerack will overnite ship them.
HTH
Mike
1996 SE MTX, Desert Violet
Blaupunkt Munchen, Dunlop
Sport 5000s, Ray
McNairy's THFix, custom air filter,
Magnecor wires,
Redline D4 tranny cocktail,
9005 lo-beams
SVT-size front rotors, EBC Greenstuff pads all around
#250323 02/07/02 08:26 AM
Autozone carries "Performance Friction Carbon Metallic" They are an aggressive pad and decent performers (A little better than Axxis Metal Masters)
However for less you could get the Mintex A/F's from BAT/SP/CTA or for a bit more the Mintex race (C-tech) pads.
I agree both Raybestos and Bendix pads are not that great.
2000 SVT #674 - Check it out!
Moderated by  Andy W._dup1
