I have the same wheel set up as you. I went with the KVR/"Brembo" cross-drilled front rotors. That will definately reduce fade under hard braking. As far as warpage I'm not sure as i've only had the rotors on for a few months. To take care of that squeaking all you have to do is bust the metal clips off of the sides of the brake pads when you're puttting the new rotors on. HTH
95 T-Red SE MTX Eibach springs, Custom cat-back exhaust, Cross-drilled front rotors, Momo air race leather shift-knob, Kenwood head unit, Kenwood 600w amp, 2 12" Infinty's, 18" Tantrums w/ Yoko Paradas, SCA CAI
