#249989 12/07/01 12:52 PM
Tarzann Offline OP
I've always planned on installing the big Baer kit one day. I would have done it already, except I could not afford both the brake kit and the 17" wheels and tires required.
It just occured to me, I don't have ABS. Am I going to be able to take advantage of their capabilities, or would a less expensive option pretty much take me to the limit of what I can modulate myself?
Hmmmm....
Any opinions?
Thanks,
Dave
98.5 SE/sport/MTX
Brembo rotors w/KVR front and Mintex A/F rear
Pro-Flow 75mm MAF w/KKM filter-Nice!
Mobil 1/K&N oil
ES MM inserts waiting-I can't get the bolt loose...need a bigger breaker bar:(
Aussie Bar and Euro ST200 struts soon!
Major mods to stereo system
Clarion 9255
All Phoenix Gold processors/MPS amps!
Vifa/Adire drivers
#249990 12/07/01 05:24 PM
I believe!!!!
ABS does not change rotors configuration! It a module connected to the Master Cylinder.
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
#249991 12/07/01 06:17 PM
H
H
actually with the larger brakes it will be better for modulation- the increased size will allow for more heat absorbsion and will help you get closer to the edge of lock up thatn with smaller brakes. also the new calipers should offer significantly less flex than the stock ones so that should help tremendously also.
'98 SVT #2253
Currently DEAD!
Cobra Paradise
Moderated by  Andy W._dup1
