#249931 12/02/01 07:28 AM
9
9
Hey guys, finally got around to putting on my new rotors and pads. Everthing went smooth with the installation, then on the test drive there was a few concerning things I noticed. First of all, I did not open the brake lines so no air should have gotten in, so I didnt bleed the system. The problems I am having are: one; the brake pedal needs to be pressed about half way to the floor to get them to start to grab, where my stock's would be brakeing from a very little touch. My second problem is with the parking brake, I used to only pull it 3 clicks and it would hold the car on even a steep hill, now when I pull it, it comes all the way up before I start to feel it holding, and even then it wont hold it on a steep hill. My questions are; first of all, why is all this happening? and second, do the calipers on the contour adjust themselves as my pads wear down? And would the fact that I adjusted a "screw" type adjustment underneath the inner rear pads all the way in have anything to do with the problem? Please someone help me, cause I need to drive 3 hours home tomorrow for school! Thanks for any help guys!!!! -Nick
~~~~1999 Contour SE Sport~~~~
-KKM True Rev
-All Cat's fixed.
-SHO Shop Off-Road Y-pipe
-Many other Mod's done...
#249932 12/02/01 03:03 PM
If your vehicle is equipped w/ drum rear brakes, you might want to try adjusting them either manually or by doing the drive-in-reverse-&-slamming-on-the-brakes-until-the-pedal-comes-up routine (the self-adjusters operate when in reverse). smile
It could also be that your self adjusters are not operating at all....that's the only reason I can think of for a front brake pad change to affect pedal actuating point...my $00.02!
Is the smoke alarm in your house also known as the "dinner bell"?
'99 Zetec VCT Daily Driver
Mild Air Filter Mod
#249933 12/02/01 04:48 PM
W
W
I'm finishing my brake job this afternoon. I'm stuck on one of the fronts, because I can't get the caliper spring back on properly.
If those springs aren't re-installed properly, your pedal could go to the floor, nevermind just halfway.
Unfortunately, I have no advice on how to get those springs on properly. I searched the forums exhaustively.
#249934 12/02/01 05:39 PM
9
9
Well, I have all four disc brakes... I will give the reverse brakeing thing today and see if that helps, someone else told me about this and I kinda laughed it off, I mean, why would they self adjust only in reverse? seems stupid to me, but oh well, if thats the way it is, then I will play by their rules and give it a try. Thanks for the help so far, and please keep the responses comming for me!!! Thanks guys! -Nick
-KKM True Rev
-All Cat's fixed.
#249935 12/03/01 01:52 AM
NICK good luck kid.....
i hope all works out well for you
i dunno about that reverse braking thing though, ive never heard that one before confused
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
see profile for website, aol name, etc
Business:WestEndMobil@yahoo.com
Personal:Corey_pimp1@yahoo.com
1998.5 SCSVT ($16000 takes it)
2001 GSXR-1000
1988 Corsica (the beater)
#249936 12/03/01 07:54 AM
9
9
Thanks guys, I think I got the parking brake to work right now, and I think the brakes just needed breaking in cause they are grabbing good now... Im going to give it another day and I will give my reports on how it is working... Again, Thanks for all the help!!!! Peace y'all... -Nick
-KKM True Rev
-All Cat's fixed.
#249937 12/03/01 10:11 PM
As a further note:
All-disc systems "self-adjust" every time the brake pedal is pressed.
Disc-drum systems adjust one of three ways:
1. You get under the car w/ the tools & adjust the rear brakes per recommended procedure.
2. Depending on vehicle design - self-adjust when brakes are applied while rolling in reverse.
3. Depending on vehicle design - self-adjust for every use/release of the emergency brake.
Check it out!! laugh
Mild Air Filter Mod
#249938 12/11/01 04:08 AM
DFT Offline
I just finished my brakes today. The caliper springs are very difficult to install. I had the same pedal problem , but installing the springs correctly fixed the problem. Correct installation is not obvious.
DFT
1998 Mystique LS
Willow Frost
#249939 12/11/01 03:06 PM
Also a good brake bleeding is needed.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#249940 12/11/01 11:01 PM
As a rule of thumb!
Only do one side of the car at a time so you can use the other as a refernce when you go to put them back together! Thats what mechanics do when they are installing brakes for the first time!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
Moderated by  Andy W._dup1
