#249570 10/04/01 08:58 PM
Yes I searched.. anyone have the correct part numbers?
T-Red SVT E0 #2321 of 6535
#249571 10/05/01 02:29 AM
bcandiloro,
I'm pretty sure that I read in one of the posts that you need the SB1010 and SB1010S. Two of each. I think SB1010S are used in the rear because the SB1010 stuck out too far. I have a pair of each on the way so I guess I'll be finding out for sure real soon now.
George Hodge
2000 SVT Silver Frost 1188/2150
DMD
HPP Rear strut tower bar
SP Motorsports "22mm" sway bar
BAT European Handling Kit
#249572 10/05/01 08:03 AM
I went though this several months ago..
The rears are the SB1010S, not a problem..
The Front.. (this was a little fiasco)
i thought they were the SB1010.. but i have an E1 SVT so i guess the bleed screws are different??.. It turned out to be the SB8125LL. (after 3 exchanges with SB's)
Some reason they were 8mm x 1.25 and not the 10 x 1.0 The stock bleed screws that came out measured 35mm in lengh so the SB8125(L) or the (LL) should work.. the L are 32mm and the LL are like 38mm. I got the longer ones.
Make sure you look carefully, and if possible take it out and measure it.
Hope this helps
Silver 98.5 SVT
5/19/98, 6023
#249573 10/05/01 12:31 PM
Hope this helps
Are you serious?!
SH!T they are sending me SB1010 for the front. God damn it!
And I have that stupid snapped bleeder in the front!
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#249574 10/05/01 01:10 PM
I emailed "Speed Bleeder" and told them to fix their info!
FORD------------Front------Rear
Contour (r/discs) SB1010 ---SB1010S
Contour SVT "E0" SB1010 ---SB1010S
Contour SVT "E1" SB8125LL -SB1010S
Regards,
Anastazi
#249575 10/06/01 08:42 AM
Yup i'm serious.. 3 returns with SB (the rep at SB was p*ssed at me) frown
I also ordered a Ford front bleed screw from Bill J. and it is indeed 8x1.25 by 35mm lenght..
Silver 98.5 SVT
5/19/98, 6023
#249576 10/08/01 12:09 PM
What about the clutch bleeder, what's that part number?
#249577 10/08/01 01:58 PM
Cool, thanks guys!
Moderated by  Andy W._dup1
