About to do a brake job and here's my thoughts, what do you?
41K on the car, all city driving in north Florida and the rotors are starting to show tiny groves.
I want to have them turned and see if they are thick enough to be spun. If not then look at another set of rotors possibly drilled.
How hard is it to remove the front and back rotors?
After resurfacing the rotors I'd like to install the Mintex pads. I'm leaning towards the 1144 but supply might be a problem. Or the green ones, maybe even the Mintex A/F.
Then flush out the fluid with plenty of DOT 4.
I would really like to do the stainless lines at the same time but my accountant (wife) has limited the budget.
Am I missing anything for a basic brake job?
The rotors usually come off real easy once you get the calipers out of the way. Sometimes they get rusted to the hub and need a bit of persuation to get them loose.
I suggest that you get yourself a Haynes manual to help with the brake job. The information there about brakes is outstanding and will benefit you greatly, especially the illustrations.
Jim Johnson
98 SVT
There no hard at all, but if you do get confused, just do one side at a time so you know how it all comes off and on.
Chow
1998 SVT #2263 of 6535
chowsvt@msn.com
4
4
I had 43k on my car when I replaced the brakes, and the rotors were severely rusted to the hub because they had never been removed before. I had to use lots of penetrating spray and a large hammer to remove them. The rotors were in bad shape, and pieces of rust were falling off when I was pounding on the hub surface of them. I had to replace them instead of cutting them.
Justin
'02 Ranger Edge ext cab
Retired: 98.5 Mystique
in florida it won't be a problem to get them off..but here in NY the only way to get them off most of the time is to ruin them by pounding on the back side with large hammer. bad corrosion in upstate NY.
96 zetec gl.dynomax exhaust(self bent) KKM intake..Bridgestone Potenza RE-910's...other mods also
87' Ford Thunderbird..Now my daily driver ( the wife uses the contour mostly) true dual exhaust with the super mystery mod.(hey there not even there!) tinted windows and stereo upgrade. the $200 car is starting to be a great car
It's fairly easy to remove the rotors, unless you live in an area that uses salt in the winter time (causes things to get rusty). I would think twice about getting the rotors turned - they may be more prone to warping if you do that. Small grooves are perfectly fine - your new pads will eventually wear into them.
Black '98.0 GL V6/MTX, tints, SVT airbox (sans fender boot), stock muffler replaced with spiral racing muffler, A6 side markers, Cougar 16" polished wheels w/ bald 205/50/16 Yoko A520's, Mobil 1 5W30, Castrol SATF/Ford FM tranny cocktail, 9005 high-beam bulbs all around, re-aimed stock foglights
As far as the steps to getting to the rotors (on front), do you only need to remove the two slide 7mm/T50 bolts to slide the caliper off, then you can remove the rotor... Is that correct?
Ryan M. Taylor
1996 GL V6 ATX Desert Violet
{__ 15" 98SE 12-spoke wheels, 205/60-15 Pirelli HP Unidirectional Tires __ KKM TrueRev Intake __ Bosch +4's __ Pioneer DEHP4000 __ 9mm Ford Motorsport Wires __ 2.25" Dual Exhaust, Catco Cat, Flowmaster 40 Series, no res __ Mobil 1 5w30 badge mod __ Pilot Millenium Series H.I.D. 55W Fogs __ Xenon 100W Highs __ Intermittent Ford P0420 CEL Option __}
http://rmtaylor.webhop.org
AIM: Vinnland990
4
4
Some, not all- have had bad luck with cross drilled rotors especially with an agressive brake pad combo. They can(and have)stress fractured from hole to hole.
Slotted rotors are another option you could look into. you might save some money in the long run.
just my opinion.
98.5 SVT
93RX7
86GT 377ci
well, i have about 43k on my svt, i just replaced my pads and rotors last week...spent about $250 on parts, and had one of my friends replace them for me...it took him no longer than half an hour to remove and replace both front pads and rotors...not that tuff of a job..if i knew it was that easy i wouldve done it myself..i believe there are two or four bolts on the calipers..once you get that off, the rotors should just pop out...i live in chicago, so i deal with rain, snow, and salt, i also wore all the way through the pads and rotors...get it taken care of before its too late...i waited too long, and know i am saving money for a new clutch...that hurts...
Moderated by  Andy W._dup1
