#249230 08/12/01 08:27 PM
dax Offline OP
need help proving theory...if my '97 GL Sport MTX had a 5 bolt pattern i could used the rear disc brakes from certain model/year mustang!!!!!
with a little modification of course. a buddy of mines say its not possible what do you guys think ????? confused confused
This is the first of punishments, that no guilty man is acquited if judged by himself.
'97 GL Sport MTX
=MODS=
Cobra 9850 radar detector
Mustangs are rear wheel drive with brake rotors that slip on over studs on the axle flange. The contour however uses a fully independent rear suspension, a dual A arm system with spindles welded to the common link between the upper and lower arms. The rear rotor or drom on the contour is mounted by means of tapered roller bearings and races on the inner hub of the disc or drum. So no it can not be done without signifigant modification, it would cost much more than it is worth.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
See my reply HERE on your multiple postings...
About adding unsprung weight and such...
2000 SVT #674 - Check it out!
Moderated by  Andy W._dup1
