Due to the sale of my 98 Contour SE, I will be selling my slightly used brake upgrades.
This consists of:
2 - powerstop 278mm x-drilled rotors in very good condition w/ no psycho emergency stops
2 - Ford-sourced brackets to clear the bigger rotors on a non-SVT Contour (SE or GL etc)or small rotor Cougar (non-V6).
set of EBC greenstuff pads to match the rotors w/ less than 10K street miles on them.
Lots of meat left on the pads, rotors have no major or deep grooves to speak of.
I also have a set of Raybestos PG series Semi-Metallic pads that I will throw in. These pads are like new in the box.
I will take $200 for all of it or I might consider splitting it up (ie:just the brackets etc)if some just needs parts.
Know what you are buying before you buy. This will bolt on to any Contour that doesn't have SVT E0 (large)style calipers, and should fit all Cougars. These tremendously improve wet weather braking ability and all-around performance.
I used it mainly for stop and go traffic in Charlotte which is notorious for psycho
drivers - more for peace of mind, but equally at home on a auto-x course or spirited mountain cruise. This is the best bang for the buck in Contour/Cougar brakes without spending lots of $$$$$$$.
