#248844 06/01/01 02:25 AM
re5cue Offline OP
I wanted to check the shoes on my rear brakes and the condition of the cylinders, but I cant get the darn drum off. They turn freely if I spin them but I cant get them to slide off! I tried WD40 and some other lubes, any suggestions?
1998.5 Prairie Tan contour,zetec,ATX
KKM;Focus Sports wires;Steel grills;Dexcool;Mobile 1;4x 15" green neon;Pre-98 console;Recontented clock and door handle lights;Code Alarm Surestart LX;Tinted;Sony and Polk ICE
#248845 06/01/01 02:29 AM
HAMMER
Chow
1998 SVT #2263 of 6535
chowsvt@msn.com
#248846 06/01/01 03:44 AM
BIG HAMMER laugh
#248847 06/01/01 04:07 AM
Is the E-Brake on??? Just a thought wink
#248848 06/01/01 04:20 AM
When you put it back together, apply anti-sieze compound between the inner drum flange and the hub flange and it will be easier to remove nest time.
The other advice you have received is really about all you can do. WD40 to soak in to try to desolve some of the rust, and a large hammer to try to get the rust to break loose. Don't hammer on the hub, just on the drum.
Jim Johnson
98 SVT
#248849 06/01/01 04:31 AM
Try a 8 in puller like for pullys. or bleed the system so the brakes give off the drum thats is how I did it. Diconnect the brake line. The self adjusters keep the drums on and shoes close to the drum.
#248850 06/02/01 02:33 AM
re5cue Offline OP
thaks guys, I'm going to try to take them of saturday. smile
#248851 06/03/01 01:09 AM
2
2
Hammer works if the drum is siezed to the hub. Strike the drum on the face where the studs are only. If the drum is a bit worn, there will be a groove on the outer lip where the shoes don't touch, this is holding it on. You might have to back off on the adjustment to move the shoes in so it will clear.
Moderated by  Andy W._dup1
