#248523 04/23/01 01:48 AM
i have a 95 gl and i have excessive brake dust on my front two wheels. I usually have to clean them at least once a week. I have replaced the pads had them checked and all that, and nothing seems to be wrong. I was wondering if any of you guys have had similar problems and what you think i could do about it
Thanks
mzatt
-95 Contour GL
-00 Integra LS
#248524 04/23/01 12:46 PM
Every contour has that problem. You need to buy a set of KVR pads or Mintex pads. they give little to no dust. you can find them at www.spmotorsports.com
1999 Silver Frost SVT
#2412 of 2760
DOB - 7/30/99
MODS:
BAT Inlet Pipe /w Monster Flow Filter, Rear Strut Brace, H&R Sport Springs, Koni Sport Struts, Panasonic CPQ-DF800u, Baer Brake Kit, Brembo Slotted/Crossdrilled rotors for rear brakes, rear KVR Pads, ASA JS6 17" w/ S-02 Pole Position, B&M Shifter, 22mm Rear Sway bar, Bassani Exhaust. SoundStream Rubicon 604 Amp, 2 SoundStream Class A 5.2 Amps, 2 SoundStream SPL 12" Subs, SoundStream SVX2 Crossover, Rockford Fosgate Capacitor.
#248525 05/01/01 04:26 PM
I
I
www.ebc-brakes.com
buy the greenstuffs for $79 and never have dust again, just dead-stop braking
'98 Tropic Green Tour SE Sport V-6 ATX
"I promise I wont modify it honey, it's a family car!"
#248526 05/02/01 12:48 AM
I've been happy with my Mintex A/F pads so far. I can't speak for the Greenstuffs--I've never used them. The carbon fiber pads I did try lasted a *very* long time, but they didn't grab well initially in wet weather--kidn of scary.
Matt Harrell
matt@mattharrell.net
www.mattharrell.net
Matt Harrell
www.mattharrell.net
#248527 05/02/01 02:21 AM
alright sounds good, thanks for the input i think im gonna go with the mintex pads.
one last q: would i be able to install them on my own or should i have it done someplace?
mzatt
-95 Contour GL
-00 Integra LS
#248528 05/08/01 01:07 AM
4
4
I installed the Mintex A/F pads 7,000 miles ago and they work great! When I wash the car, the wheels stay clean for at least two weeks, and even then, there's not nearly as much dust as there normally would be with the stock pads during the same amount of time.
Justin
'02 Ranger Edge ext cab
Retired: 98.5 Mystique
#248529 05/09/01 12:55 AM
I have a early 98 SVT what are my best options if I want Pads that perform well and have now dust and no warmup needed.
Do they make the greenstuff for the early models.
Thanks
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
#248530 05/09/01 04:10 PM
Call Joe at SP MotorSports he is great.
Suggested I get the KVR Carbon Fibers. I haven't installed them yet because my stock rotors are below spec and until I can buy new rotors I am gonna wear out the cheap pads I have. I don't want the thin rotors to warp with good pads on them.
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
Moderated by  Andy W._dup1
