Page 2 of 2 1 2
#248499 05/05/01 10:26 AM
I have the brembo cross drilled and slotted rotors with friction master titanium pads,i have had them on over a month and autocrossed with them last week and they performed awsome.I got mine from Brake Warehouse they advertise in car and driver magazine.The phone number is 1-800-814-0702 talk to randy.It cost me around $300 for the rotors and pads with shipping,they came sealed in brembo boxes with brembo install info,they come in cross-drilled and also cross-drilled and slotted.Talk to randy,the contour se 260mm are easily available from brembo the svt 280mm are a little tougher to get he said.They are awsome and way better than stock.
chris
2000 contour se sport V6
tropic green,gray leather.
K&N filter,Brembo crossdrilled/slotted rotors,Magnaflow stainless mufflers/Borla tips.
OEM SVT body kit
Hancook winter tires
on Focus wheels.
1999 Ford Explorer XLT,Gray cloth power lumbar,rear a/c and radio,AWD.
K&N filter,Edelbrock IAS shocks,and Backcountry step bars.
Mobil One used in both!
#248500 05/05/01 04:28 PM
Chow Offline OP
Wow thanks for the info, I got diffrent ones thought....... Mine are oversizes rotors , 12' to be exact and 11 in the rear, but need brackets to put them on.
Chow
1998 SVT #2263 of 6535
chowsvt@msn.com
#248501 05/09/01 10:52 PM
E
E
I have a set of cross drilled Brembos on my GL and they warped after only about 9k miles. I think I am going to try the gas slotted ones next as they are supposed to be less succeptible to warping.
1996 GL Zetec
KKM Air Filter,Brembo Rotors,KVR Brake Pads,Koni Struts,Eibach Springs,Focussport,Spark Plug Wires,Accel EDIS Coil,Speedo with a tach,BNMotorsports white face gauges ,E&G Classics Billet Aluminum Grille,B&M Shift Knob,Richbrook E-Brake Handle Cover,98+ Sail Panels,PIAA 510 fogs,Badgeless
#248502 05/13/01 02:44 AM
Wow. a 12' rotor wouldn't fit in my rims, let alone the wheel well. I think I've only seen one 12' TIRE in my life... and that was when I lived in Texas.
(Just joking with you)
Have you put in your $0.02 to save contour.org?? Put in what you can spare to keep the site up. Check the General Forum.
David
* 2k Black SVT on 17" Konig/Yokohama
* MB Quart all around; Alpine 7995, DEI/Alpine amps; Dynomat
Soon to come:
19" HRE 445s under GC/Koni Setup, Custom passive-AWD kit, 2 small Sequential Turbos running low boost, Sequential 6-speed, Widebody Kit, custom black-red chameleon paint; on and on...
Page 2 of 2 1 2
Moderated by  Andy W._dup1
