Posts: 253 |
My stock rotors have become badly warped over the winter and i want to replace the rotors and pads with something a bit more. I'd love drilled or slotted rotors but might not want to spend the $$$. so how much does this stuff cost? I'm looking for all 4 wheels, new rotors and pads for a 1998 se v6.
don't drink and drive.
Posts: 1,355 |
Take a look at the kits from BAT or SPMotorsports.com Probably the best way to go if your replacing everything, cheaper too in the long run.
Cheers.
------------------ Simon W. 96 SE V6 MTX Tereador Red Grizzly OEM Clutch Kit KKM Induction KKM Pedal Covers B&M Shift Knob Tint Poineer deck/2 10"subs Sony Explode amp.
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 852 |
BAT does not seem to stand behind their product. I would send my money some other way.
Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix, custom shift boot, monsterflow intake, Ecotek valve Quasi dual cardoctor exhaust. Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Posts: 1,861 |
You can still go for the bigger rotors and it does help. You can get the caliper brackets from Bill Jenkins or your local Ford dealer to use your existing calipers or you can buy the larger early SVT calipers. Jim Johnson 98 SVT Originally posted by mangler: BAT does not seem to stand behind their product. I would send my money some other way.
Jim Johnson 98 SVT
Posts: 1,701 |
Rotors are about $30 each. The BAT econo (stock) rotors really are nicer than the standard auto-parts-chain-store rotors. A set of 8 pads can go from about $60 up. Check the BAT catalog, even if you don't buy there. I've had good results with their parts, but there is some very good brake info on their site. ------------------ Scott 95 SE-2.5L ATX
Posts: 10 |
You can upgrade fairly cheaply now. Get Mintex pads from BAT - cleaner and they stop great. Upgrade to larger rotors by buying Cougar V6 aftermarket units. I paid <$60 each. If you do go the larger rotor route, and I think it is very worthwhile, you have to reposition the calipers by either buying the brackets from BAT, or more recently caliper brackets are now available from Ford. I got mine from Ascadero Ford - the web site is mentioned on the CEG site.
------------------ 00 SE Sport V6 big rotors Mintex pads-no black dust Pioneer/Infinty wanted an SVT but wanted an ATX more
00 SE Sport V6 big rotors + EBC pads= deep corners Pioneer/Infinty
Posts: 774 |
Here's an option. [img] http://albums.photopoint.com/j/View?u=1447543&a=11678211&p=41589302[/img] They are not cheap, but damn do they STOP! ------------------ '98 T-Red Contour SVT #2767 of 6535 DOB: 8/97 --Words to live by-- "Don?t sweat the petty things, and don?t pet the sweaty things." "If you don't like where you are, change it! You're not a tree." "The philosophy of the rich versus the poor is this: The rich invest their money and spend what's left; the poor spend their money and invest what's left."
'02 B-Yellow Subaru WRX #379 '98 T-Red Contour SVT #2767 (had)
Posts: 65 |
Everything that I've read suggests that you should not buy Ford rotors - they've been reported to warp quickly. I put Bendix rotors on my Tour and have been happy with them. Brinn Reily convinced me to do this, and he was also very satisfied with Bendix.
Barry
------------------ 96 Contour SE
-- Barry Wolf 1996 Contour SE MTX Midnight Red, Parchment leather Brakes: Bendix OEM size discs, Carbon Metallic Pads, Parking Brake TSB kit Engine: New IAC valve, new EGR valve, new cat, new water pump, moose fix kit, K&N drop in filter Tranny: Redline ATF + Ford Friction modifier Interior: Pioneer CD receiver, Pioneer speakers, Ford RS shift knob, Ford vinyl floor mats (great purchase!) Handling: E1 SVT Rims, Yoko AVS-I 205/55ZR16 (like butter) meats Other: High beam bulbs in low beam position, new trunk vent Other problems: leaky PS pump - fixed with 2 oz stop leak, 1 quart oil use per 2K miles Mileage: 62K (August 2002)
Posts: 852 |
Nice wheels 98redSVT!
What brand are they? Are you satified with them? How much?
------------------ Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix
Posts: 774 |
That is acutally my friends SVT. Those wheels are Rage Race 10, 7x17. You can buy them at www.discounttire.com , He say's he lkes them but they are a PITA to clean! ------------------ '98 T-Red Contour SVT #2767 of 6535 DOB: 8/97 --Words to live by-- "Don?t sweat the petty things, and don?t pet the sweaty things." "If you don't like where you are, change it! You're not a tree." "The philosophy of the rich versus the poor is this: The rich invest their money and spend what's left; the poor spend their money and invest what's left."
