Posts: 216 |
Can anyone recommend a good muffler shop near Atlanta? I need to replace my main cat, but I also want to remove the resonator (replaced with a straight pipe) while it's up on the racks.
I was quoted a price of $50 to do the resonator removal only at Nationwide Mufflers near Decatur/Tucker, but I think that's kinda high since some on here had it done for around $20.
Thoughts?
Thanks ya'll.
-Tim, Former crush: a '95 Contour GL 2.5L, 5-speed. Current love: 2001 Toyota Tundra SR5 King-cab 4x4.
Posts: 2,148 |
I got my custom work done at Andy's Muffler in Snellville, GA. From Stone Mountain take 78 East to highway 124 in snellville. Take a left on 124 and go about a block. Andy's muffler is on the right. If you see the hifi buys, you've gone too far.
They built my custom y pipe, cut off my third cat and resonator, and installed custom pipe and a bullet muffler all for around $250. Maybe they can help you out too.
Former owner of 1999 SVT Contour #555
Posts: 216 |
That sounds awesome! Thanks for the input. I was probably going to spend around $200 for a replacement cat, resonator removal, and labor anyway, so I might as well get the REAL setup for only a few bucks more. Sweet!
Isn't it illegal to have the main/3rd cat removed? (Not that I care!) Don't the GA emissions inspectors look for one underneath? But I'm sure Andy's Muffler will know the score...
Posts: 2,148 |
Originally posted by tim935: That sounds awesome! Thanks for the input. I was probably going to spend around $200 for a replacement cat, resonator removal, and labor anyway, so I might as well get the REAL setup for only a few bucks more. Sweet!
Isn't it illegal to have the main/3rd cat removed? (Not that I care!) Don't the GA emissions inspectors look for one underneath? But I'm sure Andy's Muffler will know the score... Hey man, it is technically illegal to tamper with any properly functioning catalytic converter. BUT this didn't phase the guys at Andy's muffler b/c they said the pre-cats should be enough to pass emissions. Since my car is emissions exempt until 2002, I'm not worried about it too much. I do not think that Georgia law requires a visual inspection, but I could be wrong. Besides...Andy's Muffler DOES EMISSION INSPECTION too! they'll help you pass. Good luck. Later on. BTW, do you happen to live in the Decatur/Tucker Area? I just moved to Tucker..I'm off of South Norcross-Tucker Rd. There are a bunch of us that met here on the boards and get together from time to time to go to events/do mountain runs/etc. You should join up with us sometime. We usually post our plans here. Later.
Posts: 216 |
Thanks again for recommending Andy's Muffler, dude. I'll swing by there tomorrow and have a chat with them . And I'll also keep an eye out for posts about locals meets and will try to make it to an event. Sounds cool!
Posts: 2,148 |
How'd it go with Andy's muffler?
Posts: 216 |
Let's just say there's a thick piece of metal tubing where a goverment-mandated piece of "equipment" used to reside!  I've still got a minor hesitation problem under acceleration (that I thought was caused by a clogged main cat), but I definitely have some new-found HP under foot. And the sound....BALLSY!
Posts: 216 |
P.S. Give me an email address and I'll give you all the DIRTY details! (Mine's tim935@yahoo.com)
Posts: 42 |
hey i live in the tucker area im off lawrensville exit i just had my exshust done at performance muffler hey let me know when you fellas meet i would like to hook up with some other tours!!
Posts: 76 |
You can also try Lord's Muffler in Buford. They have done a good bit of custom work for some of my father's cars
Scott Doughtie 99 SVT, Tropic Green KKM, 73mm MAF ASP Pulley Redline Synthetics Side Markers Recontented Clock Rear Dome Light Lighted Sunroof Switch Mesh Grilling Motorsport 9mm Wires Kumho Ecsta Supra 712s Bosch Platinum +4s
