Guage pod - AutoMeter Phantom - Fuel Air - Fuel Pressure - Vaccum/Boost
Fuel pressure sender hooked up to the schrader valve using Holley Part # 16785NOS (1/16 X 1/8 NPT). The elbow is from Auto zone.
Vaccum/Boost guage I tapped into the upper intake with a 1/8 NPT tap.
The fuel air is hooked onto the white with red wire.
Under normal cruising @ 50mph, the vac reads 18-20in and the fuel reads 46-48psi.
At WOT the vac is 0 and the fuel peaks at 56-58psi.
Neil and Jim say the fuel air guage is NOT very accurate and I should get the APEX.
I can get her to run lean with the optimizer but no voltage, just flashing green bars. I'm going to try my volt meter and see if I can adjust the mix to read .94VDC under max load.
