Page 2 of 2 1 2
#31306 06/26/01 03:18 PM
Done this several times, keeping the reverse lockout (RLO) means only cutting off about 3/4 inch to maintain the lower clearence for RLO.
Using an after market knob with a set screw alloys you to shorten is as much as you want. And you can use what ever knob you want that doesn't have the RLO hole on the bottom.
Start off with 2 inches and go shorter from there.
#31307 06/26/01 04:16 PM
1
1
Guys! Don't do it yet! When I went to the Plattsburgh meet, we discussed about why can't we do it on my car (and all pre-98's). The problem is - you have to remove the entire unit to do this. If you don't and just cut the shifter, you'll cut the rod that pull the reverse lock-out too. The result is opposite to what you think - you can't shift into reverse at all because you can't pull the block up. If you want to cut the shifter, you have to get under the car and take the shifter to rod linkage apart then either grind the block off or disconnect the mechanism and re-adapt the lockout at a lower position (latter is major PITA).
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
#31308 06/26/01 04:57 PM
I just had my shifter cut in my 98 Sport, Love it so far, I had 3 inches cut off and rethreaded, total? $12 total and an hour worth the labor and I love the way it feels, I took the reverse lockout and cut it way down so that my shift boot could still fit onto the little ring that holds it up, but there still is alot of slack on my shift boot, btw they need to use a 12mm diecast.
Ryan
98 V6 Lots-o-mods SOLD
88 Daytona Shelby Z TII (The beast)
87 Daytona Shelby Z TII (Holy 20 psi of boost batman!)
Mods- 3" Downpipe, Hi-Flow cat, 3" mandrel bent exhaust with Dynomax Ultra flow. Manual boost controller, TurboXS blowoff, 5th injector, large canister wastegate, Nitrous Express go-fast-be-happy kit, ported exhaust manifold, ported intake manifold, upgraded motormounts, eibach springs, strut tower brace. Oh and 20 PSI to boot.. my oh my...
#31309 06/27/01 05:15 AM
Wait...wait...wait! If this is true, then how have other pre98 owners succesfully cut thier shifter down?
Now I'm totaly confused confused
Simon W. Las Vegas.
96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!)
1999 SVT Engine
SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT
"it's only nuts and bolts" - Terry Haines
"Drive it like you stole it" - Me!
#31310 06/28/01 07:06 AM
I just cut off 2 1/2 inches of my shifter and it works great. Only problem I've run into is as I was screwing the knob on the whole shifter assembly rotated. If any of you know what I did please help.
96 SE
SCA cold air intake
Cat-back exhaust
Flowtech muffler
Short shifter
#31311 06/28/01 01:34 PM
Yes the pre 98 cars have a rod up through the center of the shifter for revese lock out.
Chopping the shifter only works on the 98 and up cars.
There has to be a way to bypass the lock out from under the car, then you could cut the shifter.
#31312 12/07/01 03:10 AM
1
1
http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=2&t=003164
If you stuff the shifter boot under the shiftknob and really push the shiftknob on, it will hold one pretty good. Mine only spins a little if I shift really rough.
Car Pics
#31313 12/07/01 05:29 PM
You don't have to re-thread the shaft!
Just buy a Shifter that is the old slide on/ screw in the side type.
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
#31314 12/08/01 12:25 AM
DAYAM!!! you sure dug up an old post of mine laugh i still want a short shifter, but there are still too many questions for me to feel comfortable about doing it to my car...
97 Zetec MTX Sport
Esslinger UDP; Nology HotWires and BERU Silverstones; Sylvania Silverstars (high beam in low beam)
Dual Fiamm air horns
Mk1 Mondeo Clear corners(and yes I made them fit....)
Boston FS80's in the front
Micah's PRE98 SVT front bumper, W/ Mirko splitter(yet to be painted)
Rally drivers do it sideways......
Email: Roknut@linkline.com
AIM: AphexTwinGrin
Page 2 of 2 1 2
