Posts: 69 |
Anyone with a Duratec/SVT motor without a hoodliner (whether you never had one to begin with or have taken your's off) have any paint problems because of this? I will probably experiment by taking mine out, but I don't want to bake or melt my paint if I leave the thing off!
Ted Bush 2000 T-Red SVT #1027/2150, Built 12/20/99 racertb@yahoo.com
Posts: 526 |
Took mine off a few months ago and no problems here. Convinced my friend to take his off his Z24 at the same time, and no problems there either, not that it matters.
99 SVT Contour 02 Protege5
Posts: 1,050 |
Took mine off last summer as it was rubbing against some of the engine components and melting/burning down at those points. No ill effects since then, you hear a little more engine noise, but that is ok!
alessandro PERFORMANCE FORDS- Unique parts for the contique and cougar SVT Owners Association - Toronto Chapter
SilVer_bulleT@rogers.com 1999 Silver SVT
Funnel Ram, PF Maf Adapter, Magnecore, Brullen Exhaust, Brullen Y-Pipe, O.Z. Supperleggera...MORE toys waiting to be installed... 177hp, 155lb-ft
Posts: 1,218 |
Chow 1998 SVT #2263 of 6535 chowsvt@msn.com
Posts: 463 |
you will not have any paint problems with the hoodliner removed. Our Contours don't run that hot... when compared to other cars... (ie, turbos, V8, V12, rotaries...)
Posts: 1,732 |
just curious, who has had their hoodliner reomoved the longest?
i thought i read that some contours didn't come with a liner???
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00 ------------------------------ 92% says your group-NOT HOT 85% says your either wrong or BLIND Blackhawk Down did NOT suck you know who you are.....
Posts: 707 |
Had mine off for 6 months or so...Put it back on..Took it off 5 minutes later...See here - Hoodliner Observations
Chad Williams chad5160@excite.com '99 SVT Frost Silver #812 of 2760 Born on Jan. 12, 1999
Posts: 677 |
Originally posted by SVT ST PETE:
i thought i read that some contours didn't come with a liner??? Mine didn't come with one but I only have an SE. I'm not positive but I think all SVT's had them.
98.5 SE Sport badgeless, MTX, KKM, SVT exhaust with resonator intact. 1985 Z51 Vette with many mods. Only used when the Tour appears to be outclassed.
Posts: 2,708 |
I took mine off a few months ago... I have a supercharger stuffed under the hood creating a lot of extra heat and I have yet to have any problems caused from it. -Mark
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Posts: 1,071 |
I've had mine off for over a year, and haven't had any problems yet.
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
