Posts: 154 |
Well I finally got my oil pressure guage hooked up and now when I first start the car it idles at about 75psi and when I floor it (car still cold) it pegs the needle past 100psi. But when the car warms up it runs at about 35-40 at idle (sometimes it goes down to 25psi and WOT it reads about 55-60 psi. For people with the oil pressure guage hooked up, is this normal. I think the sending unit may be bad not sure though. Interesting to see how it changes all the time.
Later
Eric 99 SE MTX Flowmaster muffler, no Res, Weapon r filter, 80mm mustang mas, Air/fuel guage, oil pressure guage 2 pod guage pod, B&M shifter, Hyper white bulbs, white front corner lights, Mobil 5w-30 syn, K&N oil filter, Air/Fuel optimizer SVT throttle body real soon! 14.7 @ 92 Best time 15.2 @ 93 Best MPH
Posts: 1,090 |
Originally posted by MYFASTSE: Well I finally got my oil pressure guage hooked up and now when I first start the car it idles at about 75psi and when I floor it (car still cold) it pegs the needle past 100psi. But when the car warms up it runs at about 35-40 at idle (sometimes it goes down to 25psi and WOT it reads about 55-60 psi. For people with the oil pressure guage hooked up, is this normal. I think the sending unit may be bad not sure though. Interesting to see how it changes all the time.
Later Yes, it is normal. My car has the exact same readings when cold and hot. Dion 98 SVT
Posts: 3,248 |
You guys with guages ever notice any flux in pressure in the long hard right turn offramps?
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 154 |
Thanks for the reply. I plan on testing the long right hand turn thing, Just have to find a place to do it. I think that k-mart parking lot will work. Later
Posts: 1,507 |
I get the same readings.
When I take long right handers and jug handles, I try and look at the gauge, and it doesn't seem to flux any.
-- Mike (Moe)Lester -- 98.5 SVT #5486 moesvt@comcast.netGet your a$$ on IM and stop wasting bandwidth!!!!!!
Posts: 1,218 |
sorry never took time to look at my guages whenI was making a hard right turn, to busy keeping my eyes on the road
Chow 1998 SVT #2263 of 6535 chowsvt@msn.com
Posts: 2,166 |
My car does about the same...
Last weekend I went to Buttonwillow race way and just my luck they were running the track backwards (counter clockwise) so I didn't have many right hand turns. But on some of right hand turns, I did see the need drop to about 18 briefly and then go back up to 50-60
Posts: 206 |
Originally posted by David Z: My car does about the same...
Last weekend I went to Buttonwillow race way and just my luck they were running the track backwards (counter clockwise) so I didn't have many right hand turns. But on some of right hand turns, I did see the need drop to about 18 briefly and then go back up to 50-60 David, please correct me if I'm wrong, but aren't you running the Mirko pan? If that's the case I'd have to guess that you'd be in dangerous territory with the stock pan. Eric
Posts: 168 |
Eric,
What gage did you go with? Where did you put in on the dash?
-Kurt
-Kurt
"I'm a little sceptical of that internet thing. After all, what's it got besides information?" -DB, 1/97
Posts: 2,166 |
Nah. I have a stock pan, that mirko pan is too rich for my blood. I'm waiting for Sho Shop to relase their baffle kit. Its supposed to come out this month I think?
