Posts: 97 |
I have a Contour 95GL, and when I am fully braked, in Drive, it vibrates. But if I put it into park, it's fine. During braking, it's smooth, just when I'm fully stopped, it vibrates a lot.
+Ford Thunderbird 1997 - V8 +Ford Contour 1995 GL [REST IN PEACE :(][Champagne|ATX] -9mm Ford Racing wires -CTA Intake Kit -Removed exaust resonator
Posts: 825 |
my car does it a little too, not sure what it is.
Adam
Electric red 95 Ford Contour GL ATX Zetec Born on date 11/1/94
Big changes coming......."hint 95 Ford Contour SVT".
"This is a place for crazy people I'm not crazy." Brad Pitt [12 Monkeys]
Posts: 860 |
All the 4 cylinder autos do it on the 'tours. Especially if you have the a/c on. Its just the way it is.
Posts: 19 |
Yes, this is normal. especially with the 4cyl automatics. Mine rattles like crazy, so does my friend's. I have just gotten in the habit of sliping it into neutral every time I stop at red light. - its really my only complaint i've had with my car.
Posts: 494 |
I can't say that I've noticed any problems like that when stopped in drive!
Stephen
96 Contour, GL, Zetec, ATX. 03/18/1996 Build Date. Drop in K&N NGK Laser Platinum Premium Spark plugs Niehoff Premium Ignition wires Wheel Well Air Intake Resonator removed. *Just the beginning*
Posts: 3,165 |
Me neither. It did start vibrating really hard while stopped at lights at about 60K, even the steering wheel would shake, so I changed the plugs, then all was fine again. It started back up again a week or so back after I had a misfire in cyl 3. Fixed the misfire and it was still vibrating hard. Reset the computer and all is smooth again. I can't even tell a diff when the a/c is on, it doesn't change anything, at least on mine.
Posts: 2,848 |
I notice alot of vibrating when the alternator is really stressed..IE: when the rear defroster is on, along with the headlights, etc. I haven't driven my zetec in a while, but it does have a dying alternator, and the vibrating stops once you turn off some accessories.
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 44 |
Yea mine does it too but I think i figured it out.... Take a look at your TEMP Guage it itz a little WARM the fan comez on at FULL SPEED which makes the dash shake....
Posts: 97 |
I dunno what it is, but it'll do it when I have NOTHING on. It does shake more, when I'm on an incline, too.
I'm gonna try to get new spark wires, cause mines are the stock ones. I hope it helps.
I also tried resetting the comp., when I installed my intake kit, but that didn't help. At first, I thought it were my brakes, which could still be a possibility. I'll keep you guys upto date on what happens.
Posts: 249 |
Originally posted by SKWAT: Mine rattles like crazy, so does my friend's. I have just gotten in the habit of sliping it into neutral every time I stop at red light. - its really my only complaint i've had with my car. That's what I did with my 96 GL Zetec also. Problem became worse with headlights/AC turned on. My final solution was to trade it in for a 97 GL with a Duratec!
