Page 2 of 2 1 2
The 9005 is the HIGH beam.
The 9006 is the LOW beam.
The 9005 recepticle assembly can be easily modified to fit the 9006 plug, however, giving you some bright-arse low beams.
If interested, let me know.
Rob
REV VT
rfolden@excite.com
95 MM V6 MTX Deep Purple
Daily Driver 80 Mile Commute
World Wide CB Radio
Just some FYI. 893 is STOCK for the SVT. If you want the higher watt (50w) fogs they are 885. I picked them up from KarParts for $9.95/each.
They won't damage your wire harness. One of the big differences with them is that they don't have a coated tip on the bulb itself. The 893's use a coated tip which hinders the light. 885's are clear all the way so it lets more light out. It's definitely an easy and cheap upgrade and makes a huge difference. They aren't projector fogs, they are flood fogs, so you won't see a huge difference in distance.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
Rob
do you have a howto typed up?
I'm looking for a set of headlights, but I also want a set of corner lights that match as close as possible. I've been using ShowOFF 9006's and Hyper corner bulbs, but they just don't match the way I want them to.Anyone have headlights and corner bulbs that actually match, and if so can send me some info ?
BLUE-1999 Contour SE-Zetec-Clear Corner Lights-Nokya 3157 corner bulbs-Kenwood Exelon X815-2-12" Pioneers-4 6x8 3-way pioneers-Cuzo 9006's & 9005's-Glowing Ford Emblem On Decklid-Blue Interior lights-Alarm W/ Remote Starter-
Daytime Running Lights-CTA Intake-Winshiel Nozzle Lights-Audi A6 Side Marker Lights-Mesh Grilles (Good Ole Gutter Guard)-Just Added SVT Exaust
Thanks For The Idea CEG'ers !!!
I went to PepBoys and looked in the "ricer" aisle. There are a nice pair of lights called HyperWhites. Very clean white, no hint of blue. Nice and bright. $20/bulb.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
Page 2 of 2 1 2
