Posts: 1,859 |
Does anyone know if there is a way to adjust the Parking brake?
**HELP SAVE CEG!!! DONATE NOW!!!**
*This space for rent* Please call... 1-800-FOR-ELKY
All proceeds go towards saving CEG
Posts: 559 |
Install new rear brake pads?
99 SVT Black/Tan #1090/2760 82K Miles.......B&M Edge Shifter Mobil1 5-30.....Side Markers Ford Synth MTX # XT-M5-QS Locking Lugs....Cup Holders Black Sail Panels...TH Fix Aluminum Gas Filler Door BS Potenza S-03's KVR Cross Drilled Rotors + Pads Dual Mode Damper - soon Clarion head unit Pioneer 2-ways
Posts: 1,859 |
already did that!! but my p-brake lever still goes almost vertical and does't hold well at all.
Jay...i could have sworn you said something about you adjusting it....did you?
Posts: 219 |
I don't think there is.
I'm pretty sure this is supposed to be a "Self Adjusting" Parking Brake.
Supposedly it should take up the slack after you engage and disengage the brake a few times.
I think I read this on the forums somewhere.
- Zack
1995 Contour LX 2.5L V6 MTX 150,000 miles and still going strong PIAA 510's (Finally I can see again!)
"It isn't pollution that's harming the environment. It's the impurities in our air and water that are doing it." George W. Bush
Posts: 482 |
Mine trips the dash light when I drive 'aggressively' so it might be TOO tight? The way I drive, the damn thing is gonna give me epilepsy
Jonathan 98 SVT E0 #4290
Posts: 219 |
Mine does that every once in a while too!
I usually find that if I just push it down, it stays out.
- Zack
Posts: 2,277 |
Originally posted by ElKy-10 months & counting: already did that!! but my p-brake lever still goes almost vertical and does't hold well at all.
Jay...i could have sworn you said something about you adjusting it....did you? jay's on vaca until Sunday. :p Mike and I are checking the ford service manual on cd right now...
Kim 2001 Mercury Cougar C2 1995 Contour GL Quote: Originally posted by shotwell: Yeah, I keep checking too. I'm afraid that just as the site goes down my car will burst into flames or something (knocking rapidly on wood)!
Posts: 594 |
from my understanding there is no way to adjust the parking brake. mine is pulling very high but I also have drum brakes. If you like try running the adjuster out on the parking brake so you can just get the brake pads in. That might take up some slack.
JoNNy V if the brake light flashes when you are driving aggressively it might mean you are low on brake fluid and it is tripping the warning light
Son - 1995 Mystique LS Zetec 5-spd --> newest "mod" -> a girlfriend by my side Father - 1995 Contour SE Duratec 5-spd Mother - 1999 Contour SE Sport Duratec 5-spd My CEG Registry My Car My Home Page
Posts: 705 |
Depending on what actuates the mechanical parking brake inside the caliper, a series of ratcheting should do the trick. Usually there is a bendix (which is why you have to screw the piston back into the caliper to install new pads) inside the piston that allows the parking brake to mechanically index the piston when the brake lever is pulled, released and pulled. IIRC Some times it helps to hold the brake pedal down to insure that the piston is tight against the rotor.
Ryan Toreador Red 1998 SVT #2843
"Performance in the hands of few"
Posts: 1,537 |
Elky,
If you just replaced the brake pads, when you pull on the EM Brake, does it hold ?
You may have to stop on the brakes a few times to give the Rear Calipers a chance to adjust the EM Rachet inside them.
Pulling a few times on the EM Lever is suppose to help them adjust as well. You have to pull it as far as it will go, and then fully release it. Think of it as a handle on a come-along.
Also make sure that the EM Cables are all lubricated, and they are not sticking. You may end up replacing the EM Cables if they are stretched or frozen.
Are you a religious EM Brake user ? If you aren't then your cables may be frozen.
If you don't use the EM Brake, moisture gets inside the cables and corrodes them solid. Using the EM Brake all the time helps to break up the rust and corrosion and keep the cables free.
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
