Posts: 132 |
Friggin' car... stalled out a handful of times this morning in rush hour traffic.
Now, there was something interesting that happened, though... After the first stall, I'd put it in drive, it would stutter, then just stall again. If I gave it some gas (not easy to do in traffic), it would lurch into gear, and stall out shortly after.
Now the fun begins... after doing this routine a couple of times, and driving it for a good 2 minutes through a parking lot, it stopped stalling, it idled better, and even my infamous Jetson's sound f/x stopped. The temp guage looked a bit higher than it was, but, nothing seriously high.
Any insight?
95 2.0L ATX GL
ummm... nothing else, really...
Posts: 1,301 |
Tropic Green '00 SVT #665 of 2150
Posts: 132 |
Well... it's been doing the same on different companies- both Shell and Mobil give me the same problem.
95 2.0L ATX GL
Posts: 219 |
Did it rain last night?
Maybe water in the system or something.
- Zack
1995 Contour LX 2.5L V6 MTX 150,000 miles and still going strong PIAA 510's (Finally I can see again!)
"It isn't pollution that's harming the environment. It's the impurities in our air and water that are doing it." George W. Bush
Posts: 1,859 |
maybe we should just blow it up..heh heh ****BOOOOM**** he he
**HELP SAVE CEG!!! DONATE NOW!!!**
*This space for rent* Please call... 1-800-FOR-ELKY
All proceeds go towards saving CEG
Posts: 3,774 |
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t 1974.5 MG B GT
Posts: 3,567 |
if its something in the engine the OBDII should have a code for it.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 132 |
I think Baco may have it... Hopefully they can disconnect it (same thing they did on Robin's Cavalier), but, I'm still hesitant. Thanks, all! J And, there has been a now- routine CEL.
95 2.0L ATX GL
Posts: 2,809 |
the CEL holds the answer......
Posts: 219 |
Originally posted by JSmith: if its something in the engine the OBDII should have a code for it. OBDI on the 95's You can use the Jumper trick to read the codes without a scanner.
- Zack
