Hey guys! I've got a bone stock 00' SVT, and I'm looking to get some mods for it! I've read the discussion for a long time now, but I think I need to ask some more experienced peoples' opnions on what I should buy. I'm looking for performance as the number one critera, but appearance/sound are also bonuses. Handling is a distant third cause I already love the handling of my SVT.
The conditions:
Has to be relatively inexpensive
Won't cause warranty difficulty
That's it! I've been thinking of a KKM Induction kit? K&M air filter? Borla Exhaust? (on the expensive side...), Superchip? (I've heard nightmares about this one..?), Tires? Rims?
I guess what I'm asking is.. what's good for a first mod? What provides the most bang for the buck for a stock SVT? What's the simplest to purchase and install with the least possible strain on the car itself? Thanks guys, I appreciate your opinions.
--Nick
2000 SVT Contour
Silver Frost
#1730 of 2150
Administrator
Administrator
4 things to start (not in any particular order)
1. B&M shifter - trust me.
2. KKM or similar intake - gives a little power (not too much but its there) looks good and sounds good (on the cheap you can get a K&N and clip it to your MAF for a similar gain, but it doesn't look nearly as cool)
3. Aftermarket cat-back - Bassani or Borla or you can roll your own (I did, I used vibrant components)
4. Y-pipe - Sho-Shop or YoDude (don't know where to get these, ask Aussie SVT)
After that go for suspension and brake stuff.
It's all about balance.
bcphillips@peoplepc.com
Most bang for the buck for a stock SVT...i'd say a y pipe of some sorts. Then, probably any exhaust upgrade (I also went custom), then I'd say freed up intake (any upgrade is better than none). That's bang for the buck IMHO.
Removing your catalytic converter, and maybe even replacing it w/ a high flow cat has the possibility to void emissions warranty...whatever that is (I'm not making that up, am I?). Also, by putting aftermarket parts on your car, Ford will not cover those parts under their warranty. But that should go without saying...
2000 Silver SVT #1602
Check it out in the registry!
Mi Coche
B&M Shifter
KKM or equivalent high-flow filter
MSDS Headers (start with most restrictive area of exhaust first)
\'94 Cobra #4963/5009, black on black, not quite stock
Formerly owned a black '00 SVT, #1972
Join the SVTOA!
RIP - Ray "Old Fart Emeritus" McNairy
kkm, y-pipe & bassani <~~sounds awesome!!
Proud former owner of.....
'99 svt - silver/blue - #2555 of 2760
Proud new owner of...
'02 BMW 330i
I'll agree on the KKM and Y-pipe for sure.
Try a B&M short shifter on another CEG'ers car before you buy. I found it to be too far of a reach, where the standard shifter is a perfect fit. The short shifter is better for shorter people (I'm 6'2")
Resonator removal, or replacement is another good one. I prefer not having it at all, others find it too boomy. This is assuming a full exhaust it too rich for your blood.
Get the heat shield from John Miks if you get a KKM, it helps sound, and in your climate, the heat underhood is an issue.
Other than that, my mods are mostly handling, audio, and pure cosmetic (though every SVT should have had an engine badge on the dash from the factory).
You can pillage an enemy once, but a customer is an endless resource.
James Oerichbauer - PFPC Global Fund Services
Ross: 1998 E0 SVT Contour, Toreador Red, Konis, Superchip, KKM w/heat shield, SHO-shop y-pipe and rear strut brace, no res, ScotchCal, Moda Sport 16x7.5 wheels with 205/55ZR16 Dayton Dayton tires... more
2
2
defentley get the kkm with teh bat inlet pipe and the b&m shorth thorw to start out with for performance and sound!!! you will not believ the sound teh kkm+ bat pipe adds...then get the y pipe and bassani that what i am doing
Its a bird, its a plane...wait!..W.T.F.W.T..?
#1800 of 2150
thumbs up for the KKM, the sound had me smiling like a cat in a canary farm for days.... smile
I'm doing the Y-pipe next... laugh
good luck, and see you in the NorCal forum wink
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
i was thinking getting some nitrous and then right away a 3L Duratec.. and a few minutes later a blower... thats what i did! laugh
99 svt contour
-its fast. period.
91 mustang gt
-its faster. period.
86 Buick Grand National
- its way faster, double period!
My opinions, I've got KKM, ASP, tint, Eibachs,Bassani, SHO SHOP Y-Pipe, and ASP UDP. This would be my order of mods
tint
KKM
Eibachs
Y-Pipe
Bassani
skip the UDP and get a B&M or heat shield, UDP do not do much, I'm sorry for all the big UDP fans, I'm not saying it will hurt your car, but just not worth the risk and not much performance.
