Originally posted by zgendron:
Baco, I remember reading about your trouble upgrading your suspension. What problems did you run into?
I was there thought the entire process.
Here's what happened.
1. every single fastener was extremely tight due to the rust that accumulates over time.
2. the upper stud on one of the front sway bar links broke while trying to loosen the nut, so that ended up in a last minute dash to the ford dealer to pick up a pair of new ones.
3. the mounting nut that holds the strut piston into the upper mount bushings also seized about half way down the threaded area. We tried soaking in penetrating oil, using 4 foot pipes on the wrenches all to no avail. When we tried to tighten the nut back down we found that too was impossible since we were bending the tools trying to free the nut.
so for fear of breaking the only tools we had or breaking the strut and not having hardware to assemble the new struts we cut our losses and re assembled the suspension and Baco drove home with one loose strut.
So, be prepared for a battle.
The work could have been done. The reason we were not able to finish the job was becasue of a lack of tooling and replacement hardware.
