There are 2 connectors for a reason. The SVT's come with a "premium" sound system. :rolleyes:
That means there is an amp located behind the glove box. The long connector is actually an amp-bypass connector. This connector plugs directly into the speaker wires that connect the factory amp. So, what you want to do is disconnect the wires that go from the amp to the door speakers. Plug the long harnass into that connector with the other end going into the back of your receiver.
Once you have done this, the amp is basically useless. The other harness is for the the power to the receiver. This is shorter and has the big black rectangle connector. Just plug this into the connector that sits behind the reciever.
Oh yeah, you have to "remove" the glovebox to get to the amp. It is the silver thing sitting a little to right of center of the glove box.
Hope this helps!!!!!
