Posts: 39 |
Just installed an SVT Exhaust on my car Y-Pipe back and have the old exhaust (Y-pipe back)available if anyone needs it. It has ~60k on it but still seemed fine. I'll hold it for a week or 2 then I'll trash it. So if anyone is in need of one; just pick it up. BTW, the exhaust I used supposedly came from a '99 SVT and the yard removed the rt rear muffler hanger from the car and left it aatached to the exhaust for my use. So if you're considering a mod to an SVT exhaust on your reg Contour, you don't need to make or order the modified hanger; just order the 99 or 00 SVT hanger from Ford and it should work.
98.5 SE Sport 99 Montana 25 Ford Model T Touring
Posts: 3,774 |
what's the diff between the V6 exhaust and the Zetec exhaust?
width? mine is looking kind rusty and nasty.
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t 1974.5 MG B GT
Posts: 219 |
How much did the SVT exhaust cost you?
- Zack
1995 Contour LX 2.5L V6 MTX 150,000 miles and still going strong PIAA 510's (Finally I can see again!)
"It isn't pollution that's harming the environment. It's the impurities in our air and water that are doing it." George W. Bush
Posts: 39 |
I don't know if the Ztec is the same or not. I guess the easiest way to check if they're the same is measure the flange hole and the distance of the bolt holes and then the location on the car; how far aft and where laterally. I bought the exhaust at Greenleaf for $100. See an earlier post. I'd add the link, but not sure how except for the text below.
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=21;t=000880
Posts: 39 |
FYI The distance from the aft side of the exhaust flange (aft of the Cat) is 56" from the fwd side of the lateral front frame. The centerline of the exhaust at the same flange is 26.5" from the very bottom of the right rocker panel. The bolt hole dia of the flange is 5-1/8" and a 2"ID for the exhaust pipe. I would assume if the Zetec has the same location, that the routing should be similar as well. Baco99, I hope this helps you out.
Looks like the link worked!
Good luck guys
Posts: 39 |
Whoops, bolt hole ida is 4-1/8"
Posts: 3,774 |
maybe i should just drive up there. are you avail tomorrow night?
Posts: 39 |
Sometime Sat would be best. Thur & Fri won't work.
Posts: 3,567 |
the v6 pipes are smaller than the svt and the zetec is smaller than the v6
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 1,537 |
Hey Ric,
Did you pull out the resonator or not ??
Resonator is the smallest diameter part of the SVT Exhaust. My SVT Exhaust had the Resonator replaced with a straight pipe.
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
