O
ov3n Offline OP
O
Could someone help me out..
I am trying to manufacture some of these kits for the cougar (possibly contour if its not too difficult of a conversion), and I need anyone here with the KKM Hood Lift kit to give me some information on them... Since KKM won't make any more (for Contours or Cougars), could you please provide me with pictures of where the struts attach to the car, and the hood and a detailed description of how they attach.. Also, the brand, model, and part number of the struts themselves would be appreciated... Thanks...
~nick
2001 Cougar V6 MTX
KKM, C&L MAF, SVT TB, SVT UIM, SVT Injectors, B&M Short Shifter, Gutted Precats (yawn), Bassani Exhaust, SVT Front and rear Engine mounts, Energy Suspension engine mount inserts, Quaife Differential, Fidanza Flywheel, Grizzly Clutch. OMP Front STB, Custom Rear STB. Various cosmetic and stereo mods.
I too would like to know!
TTT wink
Howard
1998 Silverfrost SVT #1612
June mods:
17" ADR RS Limited Limix Wheels
with 215/45/17 Yokohama AVS Sports
I got mine at Auto Zone for $20 each. They go by the brand name Mighty Lift part # D95247. The cartridge is about 9 inches long with ball ends. The kit, called hood lifts, comes with 4 - 8mm threaded ball ends, 2 long shank and 2 short shank. You will have to find 2 ball ends with 6mm threads to replace front bolts on the hood bracket. Some of the other kits have these. I got mine from my brother that he had left over from a kit he had installed on one of his cars, maybe an Eagle Talon.
What I found was the ball will let the cartridge move about 15 degrees from being perpendicular to the shank of the ball end. This allows you to screw the short 8mm ball right into the hole where the body screw comes out of the fender, there is no bracket to be made. When you remove the body screw you will need to drill out the spring steel nut to ¼” or 17/64”. This is just enough to screw the 8mm ball into spring steel nut and then back that up with a hex nut. The ones in the hood bolt right into the front hole of the bracket mount.
There are two things to be careful of:
1. When drilling the drivers side fender hole out, be sure to slide a sheet metal shield between the bolthole and the wiring harness, so it won't be damaged as the drill bit goes through. I also made a small sheet metal guard to rap around the wiring harness so the nut from the ball end wouldn't rub into the harness.
2. When installing the cartridge, install the fender ball first. This will make sure you get that one on good. Then bring the other end up to the ball on the hood.
-Bill D.-
1998 Silver SVT #862
Mods: MOMO Racers 7.5x17, 17X215/45 Potenza RE730, Color matched GTS Headlight Covers, OPM Strut Bar, K&N Filter, Hood Lifts, Eibach Springs, Alpine CDA-7875 w/4 Polk EX & 2 Jensen Tweeters, B&M Short Shifter, Bullitt Aluminum Fuel Door, Billet Aluminum Control Knobs and SVT Lighter, Aluminim E Brake Handle, Borla Exhaust, SHO Y-pipe, Aussie Bar, Splitter (ready to install), Indiglo Instruments
Master P
Master P
