Page 3 of 3 1 2 3
#227821 04/07/02 01:52 PM
Roadrunner, the IAT sensors are not in the airbox on a stock SVT because they never came with an "Airbox" it came with a cone style filter with a plastic casing over it. The sensor is in the flexable air pipe between the maf and throttlebody. It came that way stock. on Non SVT the IAT is located in the airbox. Hey Mike, post those pics.
2000 Roush Cougar Stage II
V6, MTX, Silver Frost
Too Many Mods to List
#227822 04/08/02 11:42 PM
Originally posted by RoadRunner:
The IAT sensor and IAC Valve are in the SAME locations for SVT and Non-SVT Duratechs.
IAT is in the Air Filter box, and the IAC is on the UIM next to the firewall and EGR Valve.
The IAT "HAS TO BE" in the Air Filter Box because it reads Incoming Ambient Air Temperature
PRIOR to the MAF.
If it doesn't, then the MAF readings are inaccurate.[/QB]
Ok, I finally took some pictures. The first 3 show's that the IAT is downstream of the MAF on my SVT. I did not have to touch it when I installed my KKM, therefore what you see is the same for a stock SVT.
[img]http://www.geocities.com/succy.geo/P4080008.txt[/img]
[img]http://www.geocities.com/succy.geo/P4080009.txt[/img]
[img]http://www.geocities.com/succy.geo/P4080010.txt[/img]
And here are pictures of a non-SVT airbox (Kim's Cougar), and an SVT airbox (Mine). See the small hole in the side of the non-SVT airbox? That's the stock location for the IAT. Notice there is no hole on the SVT airbox.
[img]http://www.geocities.com/succy.geo/P4080011.txt[/img]
[img]http://www.geocities.com/succy.geo/P4080015.txt[/img]
88 Grand Marquis
00 SVT Contour (1584)
64 390 FE Big Block
02 Honda Spirit 750
#227823 04/08/02 11:46 PM
thanx mike - i thought my suspicions were correct. wink
#227824 04/27/02 01:15 AM
Is the MAF sensor? The thing with the 6 little wires... and that black thing on top... laugh
My motor is out of the car and "some how" the mechanic said it cracked... "but it doesnt affect/effect (which ever) anything" was what the guy said... but I want to buy a new one... anybody?
Page 3 of 3 1 2 3
Moderated by  baco99, frenchblueC2_dup1
