#29345 05/16/01 01:58 PM
Rara Offline OP
Administrator
Administrator
Does anybody else's B&M hit on the shifter support block?
What I mean is the stick itself, just above the pivot ball, hits the mounting block (the support part around the mounting ball) on shifts into second, sometimes 4th.
Does this happen to anyone else? If I try to shift hard into second, it won't let it "pop" unless I hold it there for a second.
It's all about balance.
bcphillips@peoplepc.com
#29346 05/16/01 02:26 PM
I have occasional trouble with the shifter while lazy shifting but that could just be my tranny. So far, I haven't missed a shift at the track in about 10 runs.
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
#29347 05/16/01 02:38 PM
I will look at it at lunch time.
I get a lound "clunk" when I shift into 4th sometimes second. that might be what your talking about..
joshua_drew@hotmail.com
AIM "nerdsalot2"
1998.5 Black Contour SVT
1998 ZJ Limited 4.0L AWD
#29348 05/21/01 03:25 PM
Have you done anything about this?
I get the clunk in 2nd and 4th too. I took it apart this weekend and all is well..
AIM "nerdsalot2"
#29349 05/21/01 04:31 PM
JVT Offline
I hit the base as well in 2nd and 4th.
Gotta take it apart and put the Dremel to use
one of these days.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
-faster than the above
---wanting a Speed Triple or Superhawk badly
#29350 05/21/01 04:53 PM
F
F
Mine hits slightly in 2nd and 4th, but I kind of like it. It makes the shifts more solid and quality feeling. I never have problems getting into gear tho. I'm devising a mod (in my head so far) that puts stops in for the 1st, 3rd, and 5th so I can get the same feeling.
'99 SVT Contour, K&N, B&M, DMD, 'Foamed' Chassis
#29351 05/21/01 09:42 PM
Mine seems just fine. No hits that I can tell anyway...Guess I'm just lucky.
Jason L Brougham
jbrougham@yahoo.com
2000 SVT Tropic Green
# 899/2150
Build Date 12/13/99
KKM True-Rev
Bassani Quiet Thunder Cat-Back
B&M Edge Shifter
OBX Billet Pedals
http://photos.yahoo.com/jbrougham
#29352 05/21/01 09:59 PM
Rara,
Anyone ever thought about using aircraft quality end links on the shifter cables.
I can't remember if the ends of the cable are threaded
#29353 05/21/01 10:44 PM
Rara,
Mine hits as well in 2nd and 4th. I have a theory on this. It seems that over time the shift cables stretch out a bit. As a result, you are no longer centered in the opening of the shifter (this could also explain why my shifter is so jerky sometimes). One of these days I'm going to get around to realigning my cables and see if it fixes the problem.
-Brad
Brad Shortt
1998 SVT Contour E1
"Stupid should hurt"
#29354 05/21/01 11:18 PM
Nope, but mine catches on the way into 5th. The very bottom of the lever (where the little ball sticks into the white plastic thingie attached to the linkage) hits the support base. A Dremel should fix it, but it never hit with the stock shifter, so I'm confused why it does now.
"00 SVT Silver Frost
Sho-Shop Y Pipe
Borla Exhaust
KKM
