Posts: 770 |
well guys it's the worst  .....put a pressure test to it and it built pressure..  so either a cracked head or head gasket...  ...so not sure what to due now..no warrenty only 35k miles on it and i still owe 10k..
2002 Acura RSX Enternal Blue Pearl Blk Leather/5-spd MT. 15.724@87.79 2.397 Sixty Foot(Bone Stock) 134.6HP 130.4TQ (Bone Stock) 139.6HP 130.0TQ (Injen Intake) -------------------------- 2000 Mustang GT Blk w/Gray Leather 5-Spd ET 13.469@102.37 60' 2.004 ----------------------- Former Proud Owner!!! 98 Blk SVT some mods.. 14.955@91.93 #1730/6535
Posts: 118 |
hey its the waterpump its not a crack head of gasket just replaced the water pump
Posts: 770 |
Originally posted by mattssvt: hey its the waterpump its not a crack head of gasket just replaced the water pump i wished it was but it's not the waterpump...
Posts: 118 |
being a ford tech,not trying to be a smart ass but how do u know it not a wate pump?
Posts: 770 |
Originally posted by mattssvt: being a ford tech,not trying to be a smart ass but how do u know it not a wate pump? put a pressure test to it and it built pressure.. while running!!!!!!
Posts: 118 |
excatly still can be the water pump,the impellar is probly broken,if you dont believe me then i want to buy your car.
Posts: 3,567 |
Not being a jerk but
ITS SOPPOSED TO GAIN PRESSURE WHILE RUNNING, THE PRESSURE IS SOPPOSED TO BUILD UP TO WHATEVER THE PRESSURE IS THAT IS PRINTED ON THE PRESSURE CAP.
A problem would be likely if it did not gain pressure, or if it built pressure and bled off quickly.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 770 |
A problem would be likely if it did not gain pressure, or if it built pressure and bled off quickly. no....it holds the pressure at 15psi..after about 5-10mins.running it was in the RED...over 22psi..
Posts: 770 |
Originally posted by mattssvt: excatly still can be the water pump,the impellar is probly broken,if you dont believe me then i want to buy your car. first off..how much??? second i'm going to put a new water pump in..either tomorrow night or tuesday..i hope your right but i have three family members two of which are certified mechanics say it's a cracked head or head gasket...
Posts: 3,567 |
oh. I must have misread your post. I thought that you were saying it built pressure higher than 0.
If the pressure is getting that high, then it is likely the relief valve in the resivor cap, that is sticking in the closed position. Change the cap and everything should be fine.
