Basically here it is...I have engine parts I am going to be installing, and maybe even more parts after that.
I was hoping to find a place, or people who have worked on the duratec before and would allow me to help too. I am looking to be installing heads and cams currently...But I may also be doing block work too.
The problem is the cost of labor if I have it professionally done. If I cut that cost down, then I'll go farther with my engine work. If you have your own shop, i could pay you, but would still like to keep costs down as low as possible.
If you can help please email me at jeremy@duratecperformance.com I may be able to help you out with some parts possibly if someone can help me get my car done.
I live in NJ...but would be willing to travel, as long as there is a place to stay.
Thanks for the help...
1995 Probe GT ATX TOO MANY MODS 1999 Cougar V6 MTX Stage 1: (Basic Mods)B&M STS, Bassani Exhaust, KKM intake w/ weapon R pipe, ProFlow 75mm MAF w/optimiser, YoDude Y-pipe w/hi flow cat, SVT TB, SVT Upper IM, OMP FSTB,AF gauge, Aerogear fiberglass hood (completed) Stage 2: (Top End Work) 19-24lb injectors, P&P heads w larger valves and HPC coated, P&P and port matched lower intake manifold also HPC coated, custom ground cams, Ford Racing 9mm wires, Bosch +4 plugs, Custom burned PAC or Diablo chip (will dyno with both), Apexi SAFC (In Progress) Stage 3: (Transmission) Quaife LSD, CM stage 3 Clutch, Fidanza flywheel (In progress) Stage 4: (Suspension)Koni adjustibles, H&R springs, Progress 21mm rear anti sway bar (Installing on Tues) Current dyno: 172.9 whp with just bolt ons and stock exhaust manifolds (not gutted), oh, and bad wires  ...
