Posts: 81 |
I need a good trustworthy shop in the local tristate area, or even anyplace within a few hours to install my heads, cams, lower intake manifold, injectors, LSD, clutch and flywheel...
I have been quoted some crazy prices, so if anyone has connections, or knows a good place, I'd really appreciate the info. I'm opting to get professional install for a few reasons, mainly, I do not have the tools to balance the 4 camshafts, plus I've never done any tranny work. Also, if a shop screws it up, they have to fix it...if I scrw up, I'm at a loss.
BTW I have a 1999 Cougar V6 MTX...
1995 Probe GT ATX TOO MANY MODS 1999 Cougar V6 MTX Stage 1: (Basic Mods)B&M STS, Bassani Exhaust, KKM intake w/ weapon R pipe, ProFlow 75mm MAF w/optimiser, YoDude Y-pipe w/hi flow cat, SVT TB, SVT Upper IM, OMP FSTB,AF gauge, Aerogear fiberglass hood (completed) Stage 2: (Top End Work) 19-24lb injectors, P&P heads w larger valves and HPC coated, P&P and port matched lower intake manifold also HPC coated, custom ground cams, Ford Racing 9mm wires, Bosch +4 plugs, Custom burned PAC or Diablo chip (will dyno with both), Apexi SAFC (In Progress) Stage 3: (Transmission) Quaife LSD, CM stage 3 Clutch, Fidanza flywheel (In progress) Stage 4: (Suspension)Koni adjustibles, H&R springs, Progress 21mm rear anti sway bar (Installing on Tues) Current dyno: 172.9 whp with just bolt ons and stock exhaust manifolds (not gutted), oh, and bad wires  ...
Posts: 3,419 |
I had my work done in the Norristown, PA area (somewhat along US 202 north of I-76).
I'll give you the trans shop info. They just did a tricky MTX-75 rebuild/LSD install. Everything cost $700. Labor was $350, machine shop for Quaife was $175, and parts was the rest (replaced some bearings to standard from off-spec rebuild bearings). They didn't pull the trans; that's included in the 3L. Dave's Transmissions 3831 Ridge Pike, Collegeville, PA 19426 610-489-2684 My 'Tour is very fresh in their minds and they passed the "Terry Haines" quality test.
I'll ask my mechanic if he would ever want to work on a Contour again. If so, he has done a great job through the trials and tribulations of the 3 liter. He is very meticulous and won't half-a$$ anything. For example, he spotted the reused axle bolts (a no-no from a previous Ford Service experience), and used plumb lies to align the subframe due to a missing alignment cone of some sort. I'll post Tuesday if you are interested. $60/hr labor rate.
Posts: 3,419 |
Contour, Cougar  toe-may-toe, toe-mah-toe I'll ask the mechanic just the same
Posts: 290 |
422 Motorsports in Oaks,Pa.They are a Ford only racing shop,but will work on street cars as well.I use to take my SHO to them.They are located in the 422 Business Center.The number is 610.630.6563 They understand the need for speed.
Posts: 8 |
Hi, I too would like to know a good shop in New Jersey. Preferrably close to or in Monmouth County. Also, are any of those above mentioned PA shops close to the Hatfield/Landsdale/Horsham area?
Thanks.
Sammy
Posts: 3,419 |
Sorry about taking so long to get back. My guy said he'd be more than happy to do a 3.0 swap again, if anyone was wondering. As well as other performance work on CDW27's.
DiLeo's Auto 2231 West Main St. Jefforsonville, PA 19403 610-539-5308
From Hatfield/Lansdale/etc, you would shoot down PA 363 to Ridge Pike/Main Street (south of Germantown Pike). Go left for 1 - 2 miles for Dileo's, go right 5 mi or so for Dave's Transmissions.
Posts: 586 |
sammy check out velocity motorsports on 206 in yardvile/bordentown...greg is a good guy...he doesnt do instals...but can get anything you want...
i dunno if you were looking for instals or not...but none the less...check him out
1996 Contour GL
