Originally posted by Lew Pierce:
One last question. Where is the best place to run the sender wire through the firewall? I don't want to drill if I don't have to. Any existing place that doesn't require the extreme measures?
Best place I found is right where you need it,just below the cruise control box,drivers side behind the strut tower,find the hood release cable coming out of the fire wall.Pull the rubber grommet out of the firewall and run your wire on top of the hood release cable so that they both run THROUGH the grommet(cable and wire),now inside the car pull back the cover on hood relase handle then the black thick padding,find the hood release cable and follow it up to the firewall,you shold be able to look up under your dash and see where the light is shinning through.Pull wire through,reinstall in reverse.
