I just want to make a vote for you applying as much as appropriate of the extra donated money to past expenses -- times you've spent your own cash to keep the site going -- instead of only to future expenses.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
I would have no problem if Lance did that, but I have a feeling that the time and work he's put into this site is worth more than the $4500 we raised Add a zero or two onto that and that would be close.
Subframe Connectors, H&R's, Koni's, Rage 5.0 17's, Pole Position Tires Removed Resonator,KKM Intake,ShoShop Y-Pipe 3 liter to be built by Terry Haines or BNoon one of these days...
