F
F
Have a chance to buy a 98 Contour SVT with 75300 miles. The body and interior are in excellent condition. Here's the kicker. The transmission makes a slight grinding noise when shifting into third gear. The engine seems reluctant to slow back to idle speeds between gears. The car will need new tires soon. I also expect to replace the shocks, probably do the brakes, and give the car a tune up. I've read many posts about the transmission problems with 5spd Contour's. I can buy the car somewhere between $5800 and $6200 from a local used car dealer. The car came through an auction. I expect to spend $2000 to $2500 to get the car in top shape. Is this a deal or a fright pig in repair bill hell?
At that price, I'd probably jump on the deal. First things first, get the VIN and post it here in a new thread. Title it, Carfax, please!
Somebody will help you out and see what's up with the car's history.
If you can get in an SVT for 8 grand, hell, I see no problem with that!
Ride: 2000 T-red SE
Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE
Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
the grind into 3rd is pretty standard, no biggie really
just the synchros
95 SE Champagne Mettalic
True Dual exhaust with X pipe and Redline mufflers
KKM Tru Rev intake
H&R Springs/KYB struts
Apex-i S-AFC
65mm Throttle Body
17" Ace Spades
4 Pt Racing Harness
Window Tint all around
New Engine @ 117k kilometers
G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass"
quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
throttle hang fix will help your rpm problem
tranny will cost ATLEAST a grand. Unless its under warranty. Plan ahead for the worst and see if it's worth it. I say even if you had to replace the entire tranny it's still a pretty good deal.
1999 Silver Frost SVT
#609 of 2760
Born on 12/3/98
KKM Intake
Removed Resonator
35% Window Tint all around
Tinted Tail Lights
ElKy Mesh Grilles
HID
Dyno'ed at 175.3HP/155.5TQ
Yeah,
You could buy the car and a raffle ticket for the MTX-75 with Quaife and it would only cost $310 to get the tranny replaced, plus a trip to Michigan wink
Ooops, the raffle is already over.
TB
Tony Boner
i work for a ford dealership. e mail me your VIN # and i can check what has been done with the car. any work with ford will show up. recalls, service, oil changes, etc.
the 3rd gear grind seems to be a typical thing. i was talking with some other individuals and synchros are a viable culprit.
1985 SVO: 4 cylinders, 5 gears, 20 PSI
1998 torredor red SVT contour: #3705 of 6535
need info on your SVTs service/recall/warranty history? e mail me...
