Got rear ended (rear bumper damage only)
and I made sure that the repair
company saved the rear bumper for me.. (new
cost of $831 unpainted)
It's black, has two marks on the rear section
where the conversion van met with the bumper,
one side tab is cracked, and there is one
additional crack (see pictures)
Anyway, shipping probably not an option as
it's pretty big (won't fit in a contour)..
Does anyone need this (maybe for an SE with
SVT exhaust - or someone trying a custom
rear bumper)? It does not have the insert
in the bumper (the flat black grated area)..
Since it's a used part and may or may not be
useable, offer me something in trade you
might just have laying around that you don't
use... Stock shifter (that I can shorten),
maybe an aftermarket intake you took off, a
Playstation that you don't use anymore since
you got that Playstation 2, unused head set
to replace the crap stock stereo, maybe a
working junkyard turbo that you never got
around to... :rolleyes: (just make sure it's
something you won't miss if the bumper
becomes an unfinished project or more trouble
than it's worth..)
Anyway, respond here, I'll check it
Only thing, keep in mind that I'll
need you to come and pick it up (bring
nothing smaller than an Explorer)
Here's the pics
(I believe there might be an additional mark
on the bumper-much like a surface scratch
around 2" x 8" long where the repair company
has no respect for your car - might be able
to be buffed out, but I'm thinking you'd
want to spray it anyway after removing the
dents...)
Crack near trunk lid..
[img]
http://albums.photopoint.com/j/View?u=1606889&a=12253345&p=49022017&Sequence=0&res=high[/img]
[img]
http://albums.photopoint.com/j/View?u=1606889&a=12253345&p=49022019&Sequence=0&res=high[/img]
Cracked right tab...
[img]
http://albums.photopoint.com/j/View?u=1606889&a=12253345&p=49022021&Sequence=0&res=high[/img]
[img]
http://albums.photopoint.com/j/View?u=1606889&a=12253345&p=49022023&Sequence=0&res=high[/img]
Cracked right tab (again)
[img]
http://albums.photopoint.com/j/View?u=1606889&a=12253345&p=49022025&Sequence=0&res=high[/img]
And final detail pic for reference....
[img]
http://albums.photopoint.com/j/View?u=1606889&a=12253345&p=49022625&Sequence=0&res=high[/img]
