Posts: 3,636 |
I couldn't get to contour.org from work today.
I come home, hoping it would be there, and sure 'nuff, still there.
I hope the T1 provider isn't planning to send the bill to our gracious host.
TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Master P
Master P
Posts: 5,455 |
I'm having to use a proxy to surf.. Comcast is comcrap tonight. Check out this traceroute..
[perry@contour perry]$ /usr/sbin/traceroute ceg.contour.org traceroute to ceg.contour.org (4.17.69.10), 30 hops max, 38 byte packets 1 10.177.128.1 (10.177.128.1) 10.571 ms 24.120 ms 8.848 ms 2 * * * 3 chcgil1wct1-atm.wcg.net (64.200.102.161) 41.331 ms 29.651 ms 36.016 ms 4 * * * 5 * * * 6 * * * 7 * * * 8 * * * 9 * * * 10 * * * 11 * * * 12 * * * 13 * * * 14 * * * 15 * * * 16 * * * 17 * * * 18 * * * 19 * * * 20 * * * 21 * * * 22 * * * 23 * * * 24 * * * 25 * * * 26 * * * 27 * * * 28 * * * 29 * * * 30 * * *
Posts: 331 |
Originally posted by perry: I'm having to use a proxy to surf.. Comcast is comcrap tonight. Check out this traceroute..
[perry@contour perry]$ /usr/sbin/traceroute ceg.contour.org traceroute to ceg.contour.org (4.17.69.10), 30 hops max, 38 byte packets 1 10.177.128.1 (10.177.128.1) 10.571 ms 24.120 ms 8.848 ms 2 * * * 3 chcgil1wct1-atm.wcg.net (64.200.102.161) 41.331 ms 29.651 ms 36.016 ms 4 * * * 5 * * * 6 * * * 7 * * * 8 * * * 9 * * * 10 * * * 11 * * * 12 * * * 13 * * * 14 * * * 15 * * * 16 * * * 17 * * * 18 * * * 19 * * * 20 * * * 21 * * * 22 * * * 23 * * * 24 * * * 25 * * * 26 * * * 27 * * * 28 * * * 29 * * * 30 * * * OOOOK ![confused confused](/ubbthreads/images/graemlins/default/confused.gif)
The Stealth Mobile.
Posts: 55 |
Does "30 hops max" have anything to do with beer? Make mine a Sam, please!
"I'm here for a good time, not a long time."
'96 GL Zetec ATX Bucketloads of miles
Posts: 3,950 |
Originally posted by XTREMECONTOUR: Originally posted by perry: [b]I'm having to use a proxy to surf.. Comcast is comcrap tonight. Check out this traceroute..
[perry@contour perry]$ /usr/sbin/traceroute ceg.contour.org traceroute to ceg.contour.org (4.17.69.10), 30 hops max, 38 byte packets 1 10.177.128.1 (10.177.128.1) 10.571 ms 24.120 ms 8.848 ms 2 * * * 3 chcgil1wct1-atm.wcg.net (64.200.102.161) 41.331 ms 29.651 ms 36.016 ms 4 * * * 5 * * * 6 * * * 7 * * * 8 * * * 9 * * * 10 * * * 11 * * * 12 * * * 13 * * * 14 * * * 15 * * * 16 * * * 17 * * * 18 * * * 19 * * * 20 * * * 21 * * * 22 * * * 23 * * * 24 * * * 25 * * * 26 * * * 27 * * * 28 * * * 29 * * * 30 * * * OOOOK [/b]I guess I know nothing about computers! ![confused confused](/ubbthreads/images/graemlins/default/confused.gif)
Master P
Master P
Posts: 5,455 |
Off the Mexican proxy I was using last night and on to another in Florida. Still have the same traceroute. 24 hours and Williams Communications (as in the BMW Williams F1 team) still can't get their router working right.
Posts: 3,636 |
Originally posted by perry: Off the Mexican proxy I was using last night and on to another in Florida. Still have the same traceroute. 24 hours and Williams Communications (as in the BMW Williams F1 team) still can't get their router working right. It worked from the office today. It is a shame I actually had work to do today :rolleyes:
Master P
Master P
Posts: 5,455 |
Back up now... I emailed Comcast a copy of that traceroute.. They replied and told me to power cycle my modem. Go figure.
Posts: 761 |
Originally posted by perry: Back up now... I emailed Comcast a copy of that traceroute.. They replied and told me to power cycle my modem. Go figure. That's always their answer about ANYTHING.... :rolleyes: Their tech support sucks ![frown frown](/ubbthreads/images/graemlins/default/frown.gif) I hate the UL/DL caps too since @home bit the dust ![frown frown](/ubbthreads/images/graemlins/default/frown.gif)
