SVTFern Offline OP
Struts & Springs for sale from my 1999 SVT. They were taken off the car with about 37000 KMs on the clock. They are in great shape. Email me at svtcontour@rogers.com if you are interested.
GOOO Leafs GOOOOO!!!!!!!!!!!!!!
laugh laugh laugh
1999 SVT Contour
Silver Frost
Bassani, Konis & Eibachs
"Low & Loud!!"
17x7 Rage 5.0 / Nitto NT555 225/40/ZR17 / Aluminum Look Dash Kit / Some Serious Bass From 2 12's
price?
96 Mystique "Spree" Duratec ATX
"They have the Internet on computers, now?"
SVTFern Offline OP
$200. Not bad for low kms I would say. Contact me if interested.
Cheers
1999 SVT Contour
Silver Frost
"Low & Loud!!"
N
N
SVTFern: How much lower/firmer are they over stock? Do you think they'll swap into my 99 Mystique? You thoughts?
Nrsstc
Toronto, Canada
99 Mystique LS V6 ATX, Cabernet Red, Window tints, Stereo mods, A6 Side Markers and newly added SVT exhaust. Coming soon: SE Skirts
After reading the suspension board, i found out that after installing svt spring/struts it actually raises a normal contique.
edit: found the link
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=46;t=000488
N
N
Wow! After reading all that, I'm really confused. Okay, so if I understand this, the SVT springs/struts would not work on a V-6 Mystique cause the SVT Contour is actually 300lbs heavier and the suspension parts are calibrated for that extra weight? Hence the higher ride hight on the normal V-6 powered car? Am I close? Hummm...You know, my car is looking pretty good the way it is. BONE STOCK!
Nrsstc
Toronto, Canada
I was under the impression that the ride height would change only if you installed the SVT suspension on a Zetec powered Contique. The Duratec V6 engines and the SVT version can't be that different in weight? Can they?
CM.
99 Mercury Mystique V6 Black
KKM, 9006 BV Bulbs, Painted Calipers, 16" Cougar Rims
Alpine 7894, CDT HD62DT front, CDT Coaxials rear, ,Mmats Pro 10's. POS amp. No RICE.
300 lbs
Moderated by  Gerald_dup1, mbb41_dup1
